AFSalmon
Joined: 5/24/2002 From: Beavercreek, OH, Status: offline
- Post edited for clarification - After you pin the main spar down, glue the ribs at 90 degrees to the spar, position the rear alignment jig, and position the rib trailing edges on the jig. I like to tack glue the ribs to the jig with med CA and always use some weight evenly distributed on the wing as I apply sheeting. The use of evenly distributed weights really helps to keep the wing firmly on the building board to assure proper alignment and prevention of twisted wings. Hope this helps!
< Message edited by AFSalmon -- 1/16/2008 1:14:37 PM >
_____________________________
Mike (Salmon) Pilkenton, Chief Slab Designer Ohio Model Planes, Team OMP Captain
