RE: Hybrid Edge
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> RE: Hybrid Edge
Page: <<   < prev  1 2 3 4 5 [6] 7 8 9 10   next >   >>
Login
RE: Hybrid Edge - 2/6/2008 12:54:33 PM
AFSalmon
Status: offline
quote:
ORIGINAL: craigteffe
I have already removed the drop across the canopy. i also thought it look like SH*T.
Plus how is the pilot going to see? LOL Keep up the good work there Craig!
_____________________________
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
(in reply to craigteffe)
       Post #: 126
RE: Hybrid Edge - 2/6/2008 4:38:56 PM
tiktock
Status: offline
started covering the wings today..... i only have 7 rolls of film, 3 rolls white, 1 yellow, 1 red,1 blue and 1 of black. i have to cover the whole plane with 7 rolls including the graphics on the top, so i'm not sure about the color scheme but i had to start somewhere
Click to see fullsize image.
Click for fullsize
< Message edited by tiktock -- 2/6/2008 5:09:34 PM >
(in reply to AFSalmon)
       Post #: 127
RE: Hybrid Edge - 2/8/2008 3:25:40 PM
tiktock
Status: offline
progress so far.....
Click for fullsize
(in reply to tiktock)
       Post #: 128
RE: Hybrid Edge - 2/9/2008 10:33:22 PM
craigteffe
Status: offline
Here are some pictures of my plane all finished up. I did not have a chance to fly it yet. The all up weight is 16lb 10oz. ballanced between 7 5/8 and 8". All left to do is take it out now and fly it. looks like too much wind tomorrow maybe next weekend.
Click for fullsize
Click for fullsize
Craig
       Post #: 129
RE: Hybrid Edge - 2/9/2008 10:37:10 PM
craigteffe
Status: offline
Oh yeah I lost the red stripe across the canopy. More pics.
Click for fullsize
Click for fullsize
Click for fullsize
Craig
       Post #: 130
RE: Hybrid Edge - 2/11/2008 1:34:29 AM
AFSalmon
Status: offline
Looks much better now Criag. We too had tremendous winds this weekend! Today we had 40 mph + gusts.
       Post #: 131
RE: Hybrid Edge - 2/13/2008 5:58:49 PM
outssider
Status: offline
Mike....am finishing up mine now....don't see anyone using flying wires on the tail surfaces ?? do we need flying wires back there ??
Also...what's the record on weight (lowest weight)...i will be under 15lb for sure....and still using stock tube and gear...
gained a total of 9.4 oz with covering (combination of monokote and micro lite covering)
if anyone is interested in weights of component parts, i have everything documented (covered and uncovered)
       Post #: 132
RE: Hybrid Edge - 2/13/2008 7:53:24 PM
Crash90
Status: offline
We sure are.
(in reply to outssider)
       Post #: 133
RE: Hybrid Edge - 2/14/2008 8:20:48 AM
tiktock
Status: offline
outssider........ i'm very interested in weight. i want to know how my frame compares to yours.
could you please give me the weight for wings with covering, stabs and elevator with covering, rudder with covering and the body without covering.
no gear and no wing tube. i don't know if this is too much trouble so, only give me the weight if possible.
also, what equipment are you using to get your total weight at 15lb?
i'm thinking of DA50 with stock muffler, 2 5955 on wings, 2 5945 on elevators, 1 5955 on rudder and most likely 3 nimh 6v batteries.
thanks
(in reply to Crash90)
       Post #: 134
RE: Hybrid Edge - 2/14/2008 9:21:11 AM
tiktock
Status: offline
this is what i came up with.
stab + elevator covered - 10 3/4 oz
wing L covered - 1lb 11 5/8 oz
wing R covered - 1lb 11 1/2 oz
rudder covered - 2 3/4 oz
body not covered - 2lb 6 1/8 oz
total is something like 6.7lb so far.
       Post #: 135
RE: Hybrid Edge - 2/14/2008 1:46:14 PM
AFSalmon
Status: offline
Wow that is impressive TikTok!
To answer your questions though I have never seen flywires on the tail of the Hybrid. Should not need them unless you are worried about how light the parts are.
       Post #: 136
RE: Hybrid Edge - 2/14/2008 6:35:33 PM
outssider
Status: offline
here are weights....weight on covered parts are without servos or linkages...in other words, right after covering.
i do not have weight of stab after covering and fuselage after covering because i glued them together and forgot but do have their combined weight after assembly.
first number is before and second number is after covering in oz.
hatch 4.1 , 4.5 (some microlite covering)
stab 5, none ( all monokote)
L elevator 1.2, 1.4 (microlite covering)
R elevator 1.4, 1.6 (microlite covering)
Rudder 2.6, 2.9 (microlite covering and slightly oversized)
R ail 6.6, 7.4
L ail 6.6, 7.4
fuselage (no hatch) 2 lb 5oz (no stab), 2 lb 13 oz (with covered stab attached, no hatch) (almost all monokote)
R wing (no aileron) 1 lb 2.2oz, 1lb 4oz (some microlite covering)
L wing (no aileron) 1 lb 2.8 oz, 1 lb 4.7 oz (some microlite covering)
gear 12.9 oz, 10.6 oz (lightened) (can get carbon fiber that weights 7.4 oz)
wing tube 6.4 stock (could save 2 oz with carbon fiber)
I was so careful about keeping the back end light i think i may be a bit nose heavy ! will need to move the rx battery rearward...still waiting on one more servo....pictures to follow soon !!
ps....if i knew i could get the back end so light, i would have put the rudder servo in the rear
       Post #: 137
RE: Hybrid Edge - 2/15/2008 1:48:16 AM
cwhite
Status: offline
15.56lbs
Click for fullsize
       Post #: 138
RE: Hybrid Edge - 2/15/2008 2:04:17 AM
craigteffe
Status: offline
cwhite,
How many flights you have on your plane now? how is she doing?
Craig
(in reply to cwhite)
       Post #: 139
RE: Hybrid Edge - 2/15/2008 2:34:30 AM
AFSalmon
Status: offline
Oh man CWhite, that is a great looking Hybrid. That's the Greg Poe scheme too and the same one we got modeled in the AeroflyPro simulator. Tons of fun!
