alpapilot
GA, USA Status: offline
quote:
ORIGINAL: craigteffe quote:
ORIGINAL: tiktock quote:
ORIGINAL: AFSalmon It's going to be hard to tell the left wing from the right wing isn't it? haha So is that clear covering on the fuse? thats to avoid any confusion and thats clear on the fuse........... anyway, i've noticed 2 things, my pull pull cables are crossed and in neutral they are tight but at full deflection they are loose......if i push on the rudder it does not want to move back but why are the cables loose at full deflection? the other is the ailerons servo chatters because of the weight of the ailerons, if i hold the plane vertical the nose goes....is that ok? Some people dont worry about slack on one side as long as they are tight at netural, I am anal about stuff like this if you want it right then this is what i do. Make sure your cables are the same at the servo and at the rudder if you have 3 at the servo you need 3 at the rudder, also i use a 3 inch SWB ofset servo arm for the rudder. The control horns should also be right on the hinge line where the pivot point on the rudder is. You will have chatter on the aileron servos untill you get some wind across them to neturlize them. Actually, you want the horn slightly BEHIND the hinge line on a pull-pull setup. Once I find the link explaining the physics I'll post it. I'm holding my 3-month old right now so...........
