Pull start problems    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Exceed RC Support - Nitro Cars >> Pull start problems
Page: [1]
Login
Pull start problems - 11/28/2007 3:34 AM
5lagd
Score: 100
Last Login: 5/24/2013
Status: offline
How do you tell if you need a new pull start? on my buggie, it doesnt always catch. any ideas?
_____________________________
Stampede 4x4 & Atomik Barbwire.
Hide Signatures
       Post #: 1
RE: Pull start problems - 11/28/2007 3:34 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
one way bearing, its behind the pullstart.
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to 5lagd)
       Post #: 2
RE: Pull start problems - 11/28/2007 4:42 AM
AllAboutFunHobbies
Score: 100
Last Login: 11/10/2011
Status: offline
The one way bearing is behind the pullstart. If you take the pullstart off carefully so the assembly doesn't come apart and the spring doesn't pop out. If it's not grabbing then it's either worn or it's possible that it's coated in oil. Take the bearing out and spray it down real good with WD-40 then take a small amount of nitro fuel in a small jar, put the bearing in the jar with the nitro fuel and swirl it around in the jar a little bit take the bearing out and let it sit and dry out. Clean the pull start shaft off. Put the bearing and pull start back on and it should work good again, if it doesn't then the bearing is probablly out.
Dealer for..Redcat, Traxxas, Associated, Cen, Racers Edge, RD Logic, Losi, HPI, E-flight, Himoto, Venom, Heli-Max, O.S...etc
Hide Signatures
(in reply to 5lagd)
       Post #: 3
RE: Pull start problems - 11/28/2007 4:44 AM
ehroof
Score: 105
Status: offline
lol
Hide Signatures
(in reply to AllAboutFunHobbies)
       Post #: 4
RE: Pull start problems - 11/28/2007 4:49 AM
ehroof
Score: 105
Status: offline
when you take it out, clean it with carb cleaner to get the oil off, if you use wd or nitro fuel,it will put oil on the one way and make it keep slipping
Hide Signatures
(in reply to 5lagd)
       Post #: 5
RE: Pull start problems - 11/28/2007 4:53 AM
AllAboutFunHobbies
Score: 100
Status: offline
I always use WD 40 and nitro fuel let it dry works great never had a problem. Carb cleaner will deteriorate the nylon inside.
Hide Signatures
(in reply to ehroof)
       Post #: 6
RE: Pull start problems - 11/28/2007 4:56 AM
ehroof
Score: 105
Status: offline
i've been doing it for several years and never had a problem, oil is what usually makes it slip and wd and nitro fuel have oil.
Hide Signatures
       Post #: 7
RE: Pull start problems - 11/28/2007 4:57 AM
midGArc
Score: 100
Last Login: 1/5/2009
Status: offline
i found with mine , when pull starter would slip i just sprayed a small shot of carb cleaner down the string hole. it works in the feild and bets taking apart. problem eliminated with electric starter.
Hide Signatures
       Post #: 8
RE: Pull start problems - 11/28/2007 5:02 AM
AllAboutFunHobbies
Score: 100
Status: offline
quote:
ORIGINAL: ehroof
Oh well then I guess I'll start doing it that way too.
Hide Signatures
       Post #: 9
RE: Pull start problems - 11/28/2007 6:58 AM
5lagd
Score: 100
Status: offline
i should have read this sooner...lol my spring popped and holy sh.. its long and hard to wind back up. took me about 1/2 hour to reassemble.lol
thx for all the help guys-i love this site
Hide Signatures
       Post #: 10
RE: Pull start problems - 8/27/2010 7:16 PM
Kazza
Score: 100
Last Login: 8/27/2010
Status: offline
i got my car 2 days ago and followed the break in precedure but when i pull the pullstart it will sttart the engine but then will ping down and stop the engine, and also i put it on and and pulled the throttle all the way and it died  can you tell me whats wrong and what to do.
Hide Signatures
(in reply to 5lagd)
       Post #: 11
RE: Pull start problems - 9/8/2010 9:03 PM
rjsdad
Score: 100
Last Login: 3/23/2011
Status: offline
LOL..I use WD to loosen the dirt and debirs and follow it up with my air compressor to clean it right off. This is how I clean the buggy as well...so far so good I guess.
Hide Signatures
(in reply to Kazza)
       Post #: 12
RE: Pull start problems - 7/24/2011 1:11 AM
kelynsdad1023
Score: 100
Status: offline
motor spray works good too .
Hide Signatures
(in reply to rjsdad)
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
