gkamysz
IL, USA Status: offline
If you couldn't find the page for Benol here it is: http://www.klotzlube.com/tech/BC-175-1.pdf 520°F or 271°C. Now realistically, when are you going to experience that temperature in normal use? http://www.maximausa.com/products/2stroke/castor927.asp Notice that Dave's and my favorite Castor is at 420°F. What does that prove, if anything? Viscosity at any temperature can be calculated if you have specs at two given temperatures. If viscosity index is the same, then the slope of the plot will be the same. The only question that remains is how hot do engine components actually run? And we all know that the larger gasoline engine generally run hotter than a glow engine and yet most of the oils recommended are of lower viscosity, quantity, and flash points. It's not as simple as castor is king because it varnishes. That is my main point and I'm trying to get people to think about it rather than repeat the old adage. Dave's story is interesting, and 40 years ago I'm sure that various oils caused problems. We are here today though. what can we say about modern lubricants?
< Message edited by gkamysz -- 12/8/2007 5:35:03 PM >
_____________________________
Greg
