Flyboy Dave
CA, USA Status: offline
....well Greg....I have much more than words to go by, thank you. Think about this....why do we have to richen up our two cycle engines 3 to 6 hundred RPM's before we launch our planes ? When we have our planes at rest, and running wide open....we can set our RPM at absolute maximum, right ? This is at a setting of maximum power....RPM, and maximum HP, right ? All good, right ? But, we cannot fly at this maximum power setting, can we ? We cannot allow the engine to run wide open, even at rest....we must richen the engine 3 to 6 hundred RPM because the engine will build up heat, and start to lose RPM. The engine will begin to sag and overheat if we do not richen it up. What happens if you peak an engine to maximum power/RPM, and then launch the plane ? Now we increase the load on the engine because it is now tasked with dragging our airframe through the air. This adds even more heat, and compounds the problem. Don't believe me ? Tune your engine to maximum rpm and launch your plane. You won't make 3 laps before your engine overheats and dies. As you know, you must richen the engine before launch to compensate for the extra heat from the added load, and the fact that the engine is running at maximum power, which in itself causes mucho heat. The same thing applies to almost any engine you want to run wide open. You can put an engine on the dyno....set for maximum power....and wind that engine up tight and measure maximum power....no problem. But you better not run that engine for more than 30 seconds or so, because that engine will over heat. FBD.
_____________________________
An engineer says.... "That won''t work". A mechanic says..."Oh yeah, watch this". "Old Age, and Treachery will overcome youth and skill". Revver Bro #4.
