How to creat an airfoil with solidworks???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> How to creat an airfoil with solidworks??? Page: [1]
Login
How to creat an airfoil with solidworks??? - 11/28/2007 5:51 AM
vmoreira
Last Login: 3/6/2013
Status: offline
I would like to draw an airfoil with solidowrk, but it seems to be very dificulty drawing an polylilne from point to point.
Thanks for all sugestions ???
I´m thinking make a Vlisp program to import airfoils from dat files...
Regards
VMoreira
Hide Signatures
       Post #: 1
RE: How to creat an airfoil with solidworks??? - 11/28/2007 5:53 AM
BMatthews
Last Login: 5/14/2013
Status: offline
Will Solidworks import a DXF or DWG file? If so then I'll point out that Profili2 can export DXF files from the print preview screen.
_____________________________
Witty saying to be plagarized shortly.....
Hide Signatures
(in reply to vmoreira)
       Post #: 2
RE: How to creat an airfoil with solidworks??? - 11/28/2007 6:05 AM
vmoreira
Status: offline
Thanks!!!
I´ll try that...
Regards
VMoreira
Hide Signatures
(in reply to BMatthews)
       Post #: 3
RE: How to creat an airfoil with solidworks??? - 11/28/2007 6:32 PM
ChrisMH
Last Login: 3/7/2013
Status: offline
I've found that exporting from Profili to dxf and importing to SolidWorks works, but the imported geometry is a bit dodgy. A better way, in my opinion, is to use SolidWorks' "Curve Through XYZ Points." From Profili, export the airfoil you want to draw to a .dat file. This will create a file of XY points for a "unit airfoil" (i.e., an airfoil with a chord that is 1 unit). I import this file into Excel and multiply each and every value by whatever I want the chord to be. I also add a third column of all 0's for the Z values. After saving the manipulated values to a text file, they can be imported into SolidWorks via the Curve Through XYZ Points.
Chris Hogan
WACO Brotherhood #15 - http://www.houseofmoy.com/waco
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
