nitrorcjunkie
FL, USA Status: offline
The purpose of reeds on say, a 2-stroke motorcycle or outboard engine are to act as valves closing the induction tract from the engine block on the downstroke. In our beloved nitro engines, the induction path is through the crankshaft. As the crank rotates, it exposes an opening in the crank, allowing the upward motion of the piston to pull a fresh charge of air/fuel into the block. As the crank rotates further, it closes this tract, allowing the mixture in the block to be pressurized and pushed thru the intake ports into the combustion chamber, so reeds would be redundant and useless. Not trying to bust your bubble, but if there were better ways to gain performance besides port grinding and polishing, somebody(probably an engineer specializing in micro motors) would have found it by now.
_____________________________
Step One: RTFM Picco .26 T-Maxx, LST, RC18b
