RE: My 1st Belt Driven Tamiya - Durga DB-01
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: My 1st Belt Driven Tamiya - Durga DB-01
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/12/2007 5:29 PM
Lunchboxer
Score: 201
Last Login: 11/7/2009
Status: offline
Yeah, but then you run bigger hole piston... that was my point.. just trying to think what would be the difference...
Ha, not a shock absorber engineer.. I have no idea.. ha!
_____________________________
LB | WW2 | TLT | TB02 | DF03 | TEgg | F103GT | TXT | Hornet | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod | CR-01
Hide Signatures
(in reply to Toonz)
       Post #: 51
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/12/2007 5:31 PM
nauticar
Score: 100
Last Login: 5/19/2008
Status: offline
quote:
ORIGINAL: Toonz
i notice that all the blue spacers are on top of your spring retainer on the shock piston rod, it should be UNDER the retainer.
Sheesh...think I was too caught up in trying to make the shocks look nice.....!
And to think I have built the shocks before for my DF03..haha! Thanks for the pointer toonz!
Dark Impact, Durga and Eunos, all Mambafied and Lipoed!
Hide Signatures
(in reply to Toonz)
       Post #: 52
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/12/2007 5:37 PM
nauticar
Score: 100
Status: offline
quote:
ORIGINAL: Toonz
900 is too heavy damping for a buggy i guess....
But 900 oil was the oil that came with the Durga kit...and the stock piston holes are not TRF-style.....that's why I thought it was a good idea to fill the shocks with the supplied oil...... I really didnt like how soft my DF03 shocks were (and I still have not changed the oil in the shocks!)
I'll see how the DB01 handles (once the darn motor comes in) ......if it's too bouncy then I'll know what to do!
< Message edited by nauticar -- 12/12/2007 5:43 PM >
Hide Signatures
(in reply to Toonz)
       Post #: 53
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/12/2007 5:41 PM
B44&501xRacerEX
Score: 100
Last Login: 11/8/2009
Status: offline
quote:
ORIGINAL: nauticar
An overall view of my slow progress so far........
Looking good! Not my type of RC though, prefer shaft drive over belt drive.
It does look similar to the 501X though, it sux the steering linkage didnt fit...
You gonna race this thing? If if was me ID give those Losi XXX-4 guys a true tamiya challenge...
Losi DT/B44 FT/Tamiya 501x "WCE"/HPI E-firestorm/Yokomo YR4 M2/TXT-1/F-150/Blackfoot Xtreme
Hide Signatures
(in reply to nauticar)
       Post #: 54
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/12/2007 5:43 PM
Toonz
Score: 100
Last Login: 9/16/2009
Status: offline
quote:
ORIGINAL: Lunchboxer
i know your point and that was what i thought too....that thick oil does makes it go wild on my DI hahahaha...
no idea why either......and when i use a thinner oil with these big holes, it became so soft....bottoms out even when i drop
it at 20cm height and that's not even 1 foot yet.....funny..maybe the flourine is too smooth .....
then i tried all the way to 1000-2000 and it just doesn't make any sense at all.....
so eventually i read that someone actually tried the TRF piston that will improve the shocks
and i bought it to try......and it makes sense after that......
tamiya gives small 2-hole to the DF02 shocks and yet big 2-hole to the DF03 shocks.......what's the rationale behind?
for us to experiment?
Hide Signatures
(in reply to Lunchboxer)
       Post #: 55
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/12/2007 5:48 PM
nauticar
Score: 100
Status: offline
quote:
ORIGINAL: bmaglinger
quote:
ORIGINAL: nauticar
Haha, the steering linkage was my fault (trying to be a smarty pants ) but at least I got it working with my NauTamiya part
Nope I don't race, I'm more of a build -> play -> display kind of guy, which explains why my kits have more bling than Mr.T
Hide Signatures
(in reply to B44&501xRacerEX)
       Post #: 56
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/12/2007 5:51 PM
Toonz
Score: 100
Status: offline
quote:
ORIGINAL: nauticar
quote:
ORIGINAL: Toonz
900 or even 1000 is quite acceptable on a regular CVA but you won't see anyone using this thick oil
on their TRF shock set up, not even on those who use AE or Losi shocks.
the plastic piston is not even enough to cover the circumfrance of the cva cylinder so i guess that's really one BIG hole for a thick oil.....
im not sure if this analysis is right or wrong.....just using common sense...
anyway, give it a try, you might have success on this shocks with respect to the weight of this car.....
Hide Signatures
       Post #: 57
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 4:43 AM
nauticar
Score: 100
Status: offline
Hop - Ups
This appeared in the mail, 3 days after I ordered from RC Champ. I guess I was lucky - quite a number of people had problems with shipping with EMS.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Toonz)
       Post #: 58
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 4:52 AM
nauticar
Score: 100
Status: offline
Hop - Ups
4 Hop-ups:
1) DB01 Front One Way #54017
2) TRF501X Adjustable Belt Tensioner#53967
3) DB01 Slipper Clutch Set #54018
4) TRF501X Stabilizer Set#53963
I've installed all the hop-ups, and my suggestion is to install them in the order I listed. I didn't do it in that order and I found it to be quite messy.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 59
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 4:55 AM
nauticar
Score: 100
Status: offline
Hop - Ups
I highly recommend the spacer set. I bought it for another project; hoever I discovered I needed it for the DB-01 too.......
Click for fullsize
Hide Signatures
       Post #: 60
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 4:59 AM
nauticar
Score: 100
Status: offline
DB01 Front One-Way Set
There will be three screws included in the set - to attach the pulley to the one-way housing. I decided to threadlock them-I dont see myself taking these two apart anytime.....
Click for fullsize
Hide Signatures
       Post #: 61
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 5:03 AM
nauticar
Score: 100
Status: offline
My diff grease is alive. Everytime I open the cap the thing oozes out without me doing anything.
Smeared the grease well at the diff cups.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 62
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 5:05 AM
nauticar
Score: 100
Status: offline
The finished product! Looks nice....but too bad it will be covered by the diff cover
Click for fullsize
Hide Signatures
       Post #: 63
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 5:36 AM
Toonz
Score: 100
Status: offline
nice hop-ups
im curious, what is the purpose of the belt tensioner?
Hide Signatures
       Post #: 64
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 6:01 AM
nauticar
Score: 100
Status: offline
Yeah Im curious too! I've not actually tweaked the tensioners at this point - but looking at the manual it seems that they're there to tighten up the area where the center pulleys are - presumably to clear up belt slack
Whether they're really is useful I can't say at this point yet!
Hide Signatures
(in reply to Toonz)
       Post #: 65
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 6:11 AM
Toonz
Score: 100
Status: offline
does that mean that its more convenient to adjust from the centre tensioner rather than adjusting from the front and rear pulleys at the gearboxes?
im just guessing cos i havent got the car yet
Hide Signatures
       Post #: 66
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 6:12 AM
nauticar
Score: 100
Status: offline
Comparing the kit and hop-up manual...... what's the difference?
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 67
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 6:18 AM
nauticar
Score: 100
Status: offline
quote:
ORIGINAL: Toonz
My thoughts exactly...because the only way I see to adjust the front and back tensioner pulleys is....to open up those gearbox covers........
And I've actually tried to adjust the pulleys (when I had those darn covers off).... even tightening them by just one step makes the belts too tight.....so my guess is the gearboxes tensioners are meant for tightening when the belt gets REALLY loose.....
Now my right arm is bigger than my left from all that screwing and unscrewing
Hide Signatures
(in reply to Toonz)
       Post #: 68
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 6:21 AM
Toonz
Score: 100
Status: offline
yes i see some differences there....
centre drive hub, less shims....i hate shims hahahhaha
longer centre shaft.....
install man!
Hide Signatures
       Post #: 69
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 6:23 AM
Toonz
Score: 100
Status: offline
hahahahaha you need a power driver to handle those screws
Hide Signatures
(in reply to Toonz)
       Post #: 70
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 6:27 AM
nauticar
Score: 100
Status: offline
The drivetrain for the DB01 is quite different from the TRF's....although the former is based on the latter....
Click for fullsize
Hide Signatures
(in reply to Toonz)
       Post #: 71
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 6:29 AM
nauticar
Score: 100
Status: offline
The slipper pads are harder than the DF03's, if my memory doesnt fail me.
Click for fullsize
Hide Signatures
       Post #: 72
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 6:32 AM
Toonz
Score: 100
Status: offline
they look thick
Hide Signatures
       Post #: 73
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 6:41 AM
nauticar
Score: 100
Status: offline
I can't find anyone who installed these yet - probably I'm the first to document.....so I had to learn the hard way that once the stock centre pulleys and the pulley holder are installed, they form a mimetic polly alloy which will NOT budge.
Spent a good half hour trying to pry the two little devils without nicking the teeth ..... and this is the result.
I HIGHLY recommend the replacement Hop - Up #53989. Hopefully for anyone who installs the slippers in the future have better luck removing them
Click for fullsize
Hide Signatures
       Post #: 74
RE: My 1st Belt Driven Tamiya - Durga DB-01 - 12/14/2007 6:45 AM
nauticar
Score: 100
Status: offline
Ahh....the finished product. Well actually there's a lot more to go heh.
Click for fullsize
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.313RCU1
