nauticar
Joined: 9/23/2006 From: Walawalana, REUNION Status: offline
This is a public service DB01 announcement The DB01 uses the same wheels as the TRF501X. This means normal hex hub wheels cannot be used (eg DF03) on the DB01. Well, actually, you CAN use them, with some modification....but they will change the overall wheelbase width. Which means you'll probably end up screwing the TRF based handling. For more information, proceed to Towerhobbies.com and type in DB01 in their product search field. They have info on the wheel type in the product description.
_____________________________
Dark Impact, Durga and Eunos, all Mambafied and Lipoed!
