nauticar
Joined: 9/23/2006 From: Walawalana, REUNION Status: offline
quote:
ORIGINAL: gman1 All i can say is WOW! Please explain how this happened, how to prevent it, and what the hell you were running in that thing? i was about to ask the same question.....and my initial reaction wasnt 'WOW' it was '****!!!' i was running my durga at the carpark, nothing unusual, when suddenly i heard kind of a high pitch squeal from the back diff when i throttle it. car doesnt push forward a lot...it moves, but a little. my initial thoughts were either the spur gear teeth were stripped (hence the high pitch squeal), or the belt somehow came loose at the rear diff (hence the loss in power). came home, dismantled the drivetrain, expecting an easy job. haha fat hope. found the rear diff in that state. the front is a one way, and its not affected. both pics are of the rear diff. my diff plates are UNSCORED. good as new. so that rules out me tightening the diff too tight....and rules out normal wear and tear. last time i checked, turning one of the rear wheels will result in the other going the other way (hence it wasnt too loose either). ball diffs were greased very generously, and from the pictures, there's still leftover grease. ball diffs were intact, none shattered. im running a MM5700, Hyperion 16C 5350 Lipos. im not sure exactly what happened, but i suspect me drifting and sliding a lot in the car park had something to do with it. whadaya all think? lol. even my trashed dark impact still has the diffs intact.
_____________________________
Dark Impact, Durga and Eunos, all Mambafied and Lipoed!
