RE: D. Normans NIGHTMARE
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Q-500 Racing >> RE: D. Normans NIGHTMARE Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: D. Normans NIGHTMARE - 1/3/2008 1:14:53 AM
PylonDave
Status: offline
Dave do you drill for the blind nuts on the firewall before or after laying the carbon on the inside???
(in reply to skull1971)
       Post #: 26
RE: D. Normans NIGHTMARE - 1/3/2008 1:33:24 AM
daven
Status: online
I did it afterwards, but its a bear to get the teeth of the blind nuts to cut through the carbon.
The plans need a CAD viewer to look at.
Search for FREE CAD Viewer and you should be able to find a free download to look at the plans.
_____________________________
Dave Norman
klasskote.com
supertrc.com
(in reply to PylonDave)
       Post #: 27
RE: D. Normans NIGHTMARE - 1/3/2008 8:41:20 AM
PylonDave
Status: offline
I wonder if it would work to install the blind nuts before laying in the carbon, by filling the threads with crisco,wax or some other greasy stuff so the threads would'nt get glued???
(in reply to daven)
       Post #: 28
RE: D. Normans NIGHTMARE - 1/3/2008 12:40:09 PM
daven
Status: online
That would work fine Dave, and it would do a nice job of holding those blind nuts in place. It would just be odd installing them to a firewall thats not on the plane
Dave Norman
klasskote.com
supertrc.com
       Post #: 29
RE: D. Normans NIGHTMARE - 1/3/2008 2:41:21 PM
vicman
Status: offline
The issue I see is that you would loose the benefit of having the nuts pull against the CF inside the plane.
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
       Post #: 30
RE: D. Normans NIGHTMARE - 1/3/2008 3:06:08 PM
Bill Vargas
Status: offline
quote:
ORIGINAL: PylonDave
Dave, thats exactly what I do. I coat the bolt with some lite machine oil, screw it in all the way, do the glass work and just un-screw the bolts when the epoxy has cured. When its time to glass the exterior, just fill it with some candle wax,,, works like a champ every time
BV
If it ain't leaking oil, then something's wrong,,, USMC, RETIRED!
       Post #: 31
RE: D. Normans NIGHTMARE - 1/3/2008 7:43:29 PM
PylonDave
Status: offline
I have seen some adds for some sort of plate installed on the back of the firewall inside, with the blind nuts in the plate. anyone used this method.
(in reply to Bill Vargas)
       Post #: 32
RE: D. Normans NIGHTMARE - 1/3/2008 7:52:21 PM
daven
Status: online
Terrence sells those at www.flyfastcomposites.com
They use to come with the Neme Q Plus, not sure if they still do. They worked fine, and you can rip em out if you happen to crash and use them again.
Dave Norman
klasskote.com
supertrc.com
       Post #: 33
RE: D. Normans NIGHTMARE - 1/27/2008 2:32:18 PM
daven
Status: online
Had to replace my OS planes, with birch stained balsa glassed au naturel , just for Albert. I know how much he likes that
Stain is drying now (doesn't take long in this dry weather). Glassed and ready for paint by the end of today.
I'll stick with Quality over Randy's Quantity
Click to see fullsize image.
Click for fullsize
Dave Norman
klasskote.com
supertrc.com
(in reply to daven)
       Post #: 34
RE: D. Normans NIGHTMARE - 1/27/2008 8:30:42 PM
Randy Etken
Status: online
Dave you know what they say “if they look fast they probably are. Those fuses of yours are “brown baggers”.
Check out these just out of the mold all composite R-200s. They look fast.
You will be green with envy when you see this new R-200.
Click for fullsize
Click for fullsize
Randy E.
I feel the need for speed. NCPL racing
(in reply to daven)
       Post #: 35
RE: D. Normans NIGHTMARE - 1/28/2008 12:02:50 AM
wkevinm
Status: offline
quote:
ORIGINAL: Kevin Matney
Im working on some thing new, More to come.
Look at all the black stuff and Kevlar. Do you think it is stronger then wood????
Kevin
Nice looking fuse. I notice you have your split along the sides of the fuse, some others have theirs through the top and bottom, Ed Smith on the bottom of the side. What are the reasons for the differences. I am currently making a plug, to be molded and am curious about the logic for the different approaches.
Do you not use a wood firewall, or only CF, what is the value of Kevlar with the CF?
Kevin Moorehouse
(in reply to Kevin Matney)
       Post #: 36
RE: D. Normans NIGHTMARE - 1/28/2008 12:47:50 AM
daven
Status: online
Randy,
I see your even painting green these days. I'll accept the flattery.
Rabbits have infested the garage, another fuse has appeared for glassing.
The brown baggers have a pretty good win percentage
Click for fullsize
Dave Norman
klasskote.com
supertrc.com
(in reply to wkevinm)
       Post #: 37
RE: D. Normans NIGHTMARE - 1/28/2008 2:33:47 AM
scoeroo
Status: offline
Randy,
What would it take to part with one of those R-200's
(in reply to Randy Etken)
       Post #: 38
RE: D. Normans NIGHTMARE - 1/28/2008 2:56:36 AM
DHULEN
Status: offline
Daven or Randy ?? They both look fast how can I get some
(in reply to scoeroo)
       Post #: 39
RE: D. Normans NIGHTMARE - 1/28/2008 3:13:38 AM
daven
Status: online
Dhulen,
Both planes have performed well up here in the NCPL.
I don't sell kits, but if your interested, check out www.supertrc.com they are for sale there.
Randy does sell some, but his backlog is usually pretty big.
Both are good planes.
Dave Norman
klasskote.com
supertrc.com
(in reply to DHULEN)
       Post #: 40
RE: D. Normans NIGHTMARE - 1/28/2008 5:07:22 PM
Randy Etken
