Kyosho
Joined: 4/9/2004 From: Lake Forest, CA, USA Status: offline
Kyosho Phantom With repeated victories in the biplane-class, Phantom has dominated all rivals at the famed Reno Air Races. As a biplane, the aggressive form of Phantom has been especially designed for peak air racing performance. The focus on speed and turning control has resulted in a scaled down model that delivers the full-size flying experience. From the start of the 2007 Reno Air Races, the original flying team proudly wears the Kyosho logo as a sign of Kyosho’s sponsorship and the close collaboration in model design. Naturally these graphics are included on the 70-class model as well. The FRP fuselage combines with balsa main and tail wings to realize an optimal lightweight structure. While the wing has a slightly larger leading edge radius than the original plane, it also produces low speed stability and stall characteristics that you wouldn’t expect from a racer. Almost completely pre-built, there aren’t many steps needed for the finishing touches so intermediate to advanced fliers will find themselves airborne in a relatively short period of time. While still regarded as a middle size, there is plenty of power and performance to experience the true excitement of air racing battles. SKU: 11077B Available - Dec 3, 2007 Features • Main components are pre-assembled. • Complete with basic color scheme. • Balsa main and tail wings are pre-covered in film. • Includes latest sponsor decals. • Unique 12% symmetrical wing type produces both high speeds and stability from large angles of attack. Included • Engine mount • Fuel Tank • Main Gear • Rudder connected tail gear • Decals • Tires • Linkage Parts Required for operation • 4-channel, 5-servo (2 mini servos for ailerons) R/C system • 4C52-70, 2C46-50 Engine • D11 x P6 - D13 x P6 Propeller • 62mm Spinner • Fuel, engine starting tools • Batteries specified for R/C system • Glue Technical Data Length: 1,220mm Width: 1,264mm Weight: 2,500g (approx.) Wing Area: 33.4dm2 Wing Load: 41.5g/dm2 (approx.) Wing Type: 12% Original synmmetrical
