Mvvs 160 glow versus gas with tuned pipe and muffler issies
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> Mvvs 160 glow versus gas with tuned pipe and muffler issies
Page: [1]
Login
Mvvs 160 glow versus gas with tuned pipe and muffler is... - 11/29/2007 2:28:24 PM
balsaeater
Status: offline
I am deciding to buy ethier get a MVVS 160 glow motor or MVVS 160 gasser both using a preferably rear mounted tuned pipe through a muffler similar to this link
ttp://www.rcuniverse.com/forum/m_6660051/anchors_6660051/mpage_1/key_/anchor/tm.htm#6660051
Both motors are sitting in the LHS at acceptable prices but only include normal mufflers but I can accept side exhast with suitable 100 degree manifold if nessary
I will always be running the motor a tad rich to keep the oil requirement as low as possible but relucant to go too low on oil levels percentages so preference is 18% synthetic in glow version no castor
The MVVS glow are popular motors for zero% nitro as they have a high compession ratio without even skimming that often other motors require
The motor is to fit a semi scale Pitts special type plane to enter and do learner mode pattern flying ( suitable kit or plan to be decided ) but mono wing type less likely for ease of transport issues as I will probably have also a electric version pattern in mono wing but its too expensive for recharging on holidays or visiting other clubs fields and dragging a 2.5KW generatoir onto airliners eeeekkkk
My prefernce is glow if I can get suffient evidence of the the costs are not too excessive in todays prices using zero nitro and 18% synthetic lubrication for its extra power compared to gasser
I would only consider to do gasser if the price of glow looks to be way too expensive or if gasser can really and truly match power of glow on the same size cc weight which I dought and I realy dont want to go to 40cc or 80cc whatever in this time mayby in 2009
Although my local club has no noise issues if its not tooo loud my preference (coming from vitualy all electric background ex mid sized 120 glow motor user ) is to keep noise reduced with lowwer revs largest suitable props and suitable rubber mounting for motor if nessary so it seems logical to have a muffler in front of the tuned pipe but could live with tuned pipe alone if it noise levels would be satifactory low for typical clubs I might visit in Spain or France
Can you indicate the fuel consumtion for glow version on zero nitro and FAI fuel or 18% synthetic and fuel consumpton for gasser and any real first hand experiences with this motor with tuned pipes and ease of tuning and noise issues
18% synthetic zero% is the fuel I use in glows and is the most popular type localy but i can make special orders for FAI 80/20 castor (but its not sure to be any cheaper )if its the only suitable fuel but I realy hate the mess the castor makes compared to pure synthetic
Also it seems looking at the pitures online of the gas version MVVS 160 it seems to be a extra add on convertion kit so does the possibilty exist if I wished in the future if methanol prices get too steep to be able to convert to gasser
I do like the very large glow motors ~25cc used in glider towing in some clubs in other near buy countries where methonal is much cheaper tha my location and some of the motors are ~ twenty years old and still going strong and not keen to involved with these often weaker and puny agricultural motor gas convertion kits out there
I am not really interested to do four strokes for lots of reasons but especial y as most of the cheaper type and even expensive ones without nitro tend to be lacking ommffff and cost to much to buy to get the good makes that realy last donkey years without major servicing
Methanol here localy cost me with 18% synthetic 17 euros ~$25 a gallon IMP from LHS ( ~ $20 a USA gallon )and if I order 45 gallons IMP drum of methanol would reduce to 8 euro a gallon IMP $~12 a gal IMP ( $9 a USA gallon ) for methanol cost making ~12 euros a gallon Imp ~$16 a gal imp ( ~12 a gal USA ) but local storage rates for storage of large quantities of fuel might make fuel cost the same as from LHS
Nitro cost way too much about double the price of the USA so its a non starter for this kind of larger motor
I figure I can afford the 17 Euros a gallon but want to plan as far ahead in case fuel prices change a lot from todays prices
Most half of all the flights will be used to tow up smaller gliders as well as a extra club tow plane to the 100cc gasser so its preferable its not to expensive and it has MAX reserve power possible to get out of trouble and better abilty for motor to suffer least damage from unintended crashes which 2 stokes usualy seem abetter able to do
Sorry for the multi question issues but over the years not keeping abreast of the glow and gasser subject with high comitment to electric dont want to be caught out with out of date info
balsaeater
< Message edited by balsaeater -- 11/29/2007 2:35:13 PM >
       Post #: 1
RE: Mvvs 160 glow versus gas with tuned pipe and muffle... - 11/29/2007 3:25:45 PM
DarZeelon
Status: offline
quote:
ORIGINAL: balsaeater
BE,
MVVS specify 10-12% castor oil and no synthetic oil, for this engine.
More oil will make your engine back-fire and throw/dislodge the prop.
Believe me, you don't want that! Don't use any more than the specified amount of oil! Don't use any synthetic oil!
quote:
Can you indicate the fuel consumption for glow version on zero nitro...
About 1 ounce - 35 cc per minute.
_____________________________
Dar Zeelon - ISRAEL - ddzeelon@gmail.com
MVVS - Jett - Nelson - Bolly - Mejzlik
(in reply to balsaeater)
       Post #: 2
RE: Mvvs 160 glow versus gas with tuned pipe and muffle... - 11/29/2007 3:40:09 PM
JCINTEXAS
Status: offline
Balsaeater quote:
"I am deciding to buy ethier get a MVVS 160 glow motor or MVVS 160 gasser" Here is something for you to consider about going with gas. How do you transport your planes to your flying field? If you have a van or station wagon, you might not want that smell of gasoline (and the dangerous fumes) in the vehicle with you. If you transport your models in a trailer, then the fumes wouldn't be an issue. MVVS makes great engines. I just wish they were more available in the US.
Regards
JC
"I've got 3-green"
       Post #: 3
RE: Mvvs 160 glow versus gas with tuned pipe and muffl... - 11/29/2007 10:24:52 PM
balsaeater
Status: offline
thanks guys you confirmed for me that my questimates were in line
looks like I should get fairly economic running with glow mayby ~ 2.75 euros ~$3.50 per 20 minute flight WOT at LHS fuel prices and mid gas ~2 euro or $2,75 landing after twenty minutes with half tank and less again with home brew mayby 1.80 euro $2.20
(some of my 90 size electric replacement s are nearly costing that per flight anyway but electric prices are dropping and fuel prices might keep rising so it giff giff and I need one hour and also need a 2.5 KW generator to do 120 sizeplus Lipo replacement models that has to be factored in so for me 90 size is realistic maxuim for electric until mayby ~2009/10 or even up to 2012 when every rental car is a hybrid with 30KW GENERATOR built in as standard )
If it gives me good 3D and hover with strong punch out its worth every penny
I sopose I can live with castor if there is no other working solution in synthetic
often in Spain and France the LHS only stock synthetic fuels which suits most of the smaller motors and wont order in castor fuels for one unknown costomer or stock Methonal neat so I cant arrive with my own castor fuel to mix
SO I WILLL HAVE TO plan ahead more than I would prefer and get the club where i go to to sell me a castor mix as most big clubs have their own castor mixxes to solve that problem
For transport its for inside the car (small compact hatch back 1000cc car)probably on a semi scale Biplane Pitts or Ultimate for compactness and for airliner travel to fly ins whatever
Gas fumes can be a serious issue for both inside the car and for airliner transport in the hold
Unless something else wild come through the glow motor is the purchase in a few weeks copled with it is like ~100 euros ~$130 cheaper than gas version which is some ~6 gallons Imp ~8gal USA fuel or 12 hours flying WOT( up to~24 hours mid gas )say ~18 hours mixxed flying ahead of the game compared to gasser before i start to paying extra premium tate for gas not faxtoring in gas fuel with 3% oil at say to ~8 (~$10 ) to ~9 euro ~$12 per gal IMP (or ~ $9 USA gal) est 3/4onz fuel consumption per minute WOT
2010 probably with euro probably falling back in value against USA $ and gasoline costs rising expect 18% synthetic glow in LHS to hit 25 euro a gal IMP and gasoiline with 3% oil to be closer to 15 euros per gal IMP mayby even 20 euros if oil hits $150 a barrel but I could be wrong the prices of all fuels might fall back down for other reasons as historicaly fuel has a tendency to peak and then go into long periods of declining prices
Any ideas on the DB rates with tuned pipe for the Glow version
Balsaeater
< Message edited by balsaeater -- 11/30/2007 8:38:55 AM >
(in reply to rmenke)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.734RCU2
