msdavid
Hello, I am new to the forum but thought someone would be interested in knowing that I was able to modify the Walkera 5#10 so I can fly it with the DX7 using the 4in1 for the E-Flite Blade CX2 (EFLH1024 60USD) and 2S batteries, the helicopter became even easier to fly and got better response , more cyclic and throtle response. It handles much better than before on slightly windy conditions. BTW, I love this bird, I also own a Lama 5 (Colco) and a Lama 4 (E-Sky), and I must say that although they are very good machines, none can be compared to the 5#10, this baby its truly amazing, smooth, robust and stable. First I was skeptical because Walkera dos not have good reputation, but when I got my 5#10 I could see that this little bird was different. Awesome machine. Ok, enough of that. I have a Spektrum DX7 radio (and some big birds and wanted to be able to use it with my 5#10 so I did some research and got it working. Those who know what the DX7 is, also know what the advantages are using this radio, but here I will give you some Idea why you could consider buying one. The DX7 is a 7 channel transmitter from a maker called Spektrum, it uses DSM2 2.4Ghz technology that eliminates possible interferences or conflicts of frequencies, has larger range and uses an small antenna. The DX7 is usually one of the pro's favorite. It is a fully computerized radio that allows you to have several programs for different machines (helicopters, planes, ect) this means that you can use the same radio with many helis. The DX7 is fully digital, so the trims and adjustments are very precise and programmable. You can program the response curve of the control sticks to your likes or level of experience. You can create mixing programs that will simplify your flying experience. For example you could create a mixing program that would automatically increase or decrease throttle according to your cyclic input (roll left, right,back or forward) this avoids your helicopter loosing thrust and going down or up when you apply cyclic. (this is just an example of a possible mix). These are just a very few possible benefits of the DX7, I could not mention all the bene |
