Tedstrickland -> RE: Walkera 5#10 (6/29/2008 11:22:18 AM)
The big 2.4GHz advantage to me was the significantly smaller antenna size and promise of "glitch-free", since I fly all my helis in the "hobby room" which is 17 X 13 feet, and filled with a large screen TV, model trains and lots of other stuff. Also, since I have mulitple Walkera helis using the 2.4 system, and they "code match" on power-on, so, I don't not need to keep multiple Tx charged up. So far so good on the 2.4 GHz 5#10 and 4#3B......I was a bit concerned 'cause of all the other stuff in the house using 2.4 (cordless phones, wireless CCD transmitters, AV transmitters for the satellite TV; etc, so far no problems..... :) While waiting for my 2.4 GHz 5#10, I did make my own whip antenna for the Walkera FM transmitter units; I used a phone to RCA metal plug from Radioshack, tapped a 4MM thread on the phone side, soldered the end for 40 inches of solid core #22 wire, then wrapped it around plastic tube, which neatly fit over the RCA end; Cut the tube, put a thread protecter [rubber cap] over the tip to hold the wire in place and put shrink wrap over it....looked and worked great; Now, 5#10 with 2.4GHz, 400 series super skids and several batteries....whoo hoo....life is good P.S. I also see that Walkera is going to release a NEW version of the micro co-ax, the 5G6-1 with CNC metal head and 2.4 GHz in July, about the size of a 4#3B....now listed on their site www.walkera.com ...can't wait..... :) P.S.S. Does Super-skids have an intermediate size set of skids that will fit the 5#10 ??? Not complaining here, as the 400's work great and fit perfectly to the frame (I also cut about one inch of skid from the rear). But, they do look a bit oversize, copared to OEM... Ted in St. Pete, FL. (my toys keep me young, as does my 5 year old...now flying Havocs)
