RE: Walkera 5#10
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera 5#10
Page: <<   < prev  1 2 3 4 5 6 7 [8] 9   next >   >>
Login
RE: Walkera 5#10 - 7/8/2008 6:50:09 PM
mr.chomper
Status: offline
I'm looking at heat sinks too. Which ones did you get?
How are your mods working out?
(in reply to Tedstrickland)
       Post #: 176
RE: Walkera 5#10 - 7/11/2008 7:40:40 PM
mr.chomper
Status: offline
I'm having tons of fun with this bird but it's also a money pit, mostly due to the fact that I'm a wreckless flyer.
My balance bar is bent and she vibrates a lot now, I've got replacements on order. If you want to see this thing fly fast (really fast) then take the weights off the balance bar, it isn't uncontrollable but it is really responsive. I've put the weights back on because I'm not smooth enough with the controls to deal with how fast it moves when the weights are off, but if you are an experienced pilot you should give it a go, its a blast.
BTW the 180 motor heat sinks fit and do a good job of cooling the motors. You can get 2 heat sinks on the front motor but I think you can only fit one on the rear motor.
So far I've broken:
1 canopy
1 set of blades
1 rotor gear (chewed up when motor backed out, make sure your motors are screwed in nice and tight)
1 balance bar (bent, but not totally wasted)
1 stock skids (replaced with super skids)
1 rear prop blade (I'm just going to remove it, though I have a replacement on order).
I fly like a mad man and I lack patience, but I'm learning that I need it because most of my crashes have been avoidable.
After reading this and other threads I will consider dropping in a lama "4 in 1" and battery to reap the rewards of the lama's better gyro. Not that I have a problem with my stock 4-in-1 but I'm using this heli as a stepping stone to a single rotor FP and I want to get used to messing with the electronics too.
All in all this is a great heli to learn on and a decent platform to modify.
I do have an issue, which is likely due to one of my gears being a little warn, that is when I spin the heli in one direction it goes up... when I spin it in the opposite direction it goes down. If the replacing the gear doesn't resolve the issue I'll have to look at adjusting whatever settings the 4-in-1 allows me to adjust (it may only be gyro gain). Either way if anyone has some words of wisdom for what is happening and how to resolve it... help a brother out.
(in reply to mr.chomper)
       Post #: 177
RE: Walkera 5#10 - 7/11/2008 7:58:34 PM
Tedstrickland
Status: offline
Could you please point to a source and part number for the 5#10 heat sinks. You said they were "180" size ???
I f/u on your recommendation for the Exceed LG from XHeli. They had free shipping yesterday....waa hooo !!!
Thanks....
       Post #: 178
RE: Walkera 5#10 - 7/12/2008 2:58:29 AM
mr.chomper
Status: offline
The heat sinks are the xtreme 180 heat sinks for the lama's and blade cx's as seen here:
http://www.boomtownhobbies.com/Xtreme_180_motor_heat_sink_Silver_for_Lama_V3_pa_p/ea007-s.htm
I just picked mine up at a local hobby shop as the ones local to me all carry e-flight stuff. They cost me about $3.50 each.
Good luck!
       Post #: 179
RE: Walkera 5#10 - 7/13/2008 5:13:43 AM
ausaero
Status: offline
Hi all,
Just wondering if anyone has had the same problem I have. I had not too minor crash a few weeks ago. 8 ft drop and damaged the main gears. Already had them replaced. However, after the repair, my 5-10 will no longer fly higher than 1 ft off the ground.
I'm not sure if the problem is with the receiver (3in1, Im using the 2.6 GHZ) or the motors. However my supplier says it must be the motors as he has had no complaints regarding the receiver. Ive also made sure that the pinions and gears are neither tight nor loose.
Any comments or suggestions would be appreciated.
Cheers,
Ausaero
       Post #: 180
RE: Walkera 5#10 - 7/13/2008 7:18:39 AM
AZheli
Status: offline
Motors? Maybe
Does the heli rise straight up, or spin?
Normally, motor sets don't wear / burn out at the same rate so as to allow rise straight up at throttle up.
Bent Inner shaft?
Gears not tightened down onto shaft flats, allowing slippage & loss of power.
Ozzie air to thin to support aerodynamic lift?
Damaged battery in crash so it does not charge to capacity?
Get a spare battery & set of motors. Try the new battery first, then change out the motors next.
IMO, it just sounds like you're not getting enough power to to throttle up enough to fly...
(in reply to ausaero)
       Post #: 181
RE: Walkera 5#10 - 7/13/2008 2:13:01 PM
Tedstrickland
Status: offline
I agree with that approach....
I doubt you had damage to both motors from the crash. If one was bad, then it would spin....out of control.
The problem seem to affect both motors equally... I would try a new battery first. If no improvement, look for other issues that affect performance of both motors.
Do the motors get real hot after a shot time of flight ? If the concentric rotor shafts are bent, even slightly - then the internal friction will limit RPMs. This could burn out your motors real quick, as they will draw more current and overheat. It does not take much friction to really limit performance.
Ted
       Post #: 182
RE: Walkera 5#10 - 7/13/2008 6:00:26 PM
mr.chomper
Status: offline
Ok, I've replaced my gears and... well I still have this one issue:
when I spin the heli in one direction it goes up... when I spin it in the opposite direction it goes down. One of the rotors clearly begins to spin slower when I do this (unfortunately I forgot which one as my computer is near but the heli is not). This leads me to think that one of the motors is screwey. I just don't understand why this would only happen when using the yaw control. Actually it does loose altitude when I try to fly it forward sometimes too.
Any ideas?
       Post #: 183
RE: Walkera 5#10 - 7/14/2008 9:03:40 AM
ausaero
Status: offline
Thanks AZHeli and Ted.
I tried all 3 of my batteries and even at full charge, I'm still unable to fly the thing any higher than 1 ft off the ground. I reckon it really is the motor(s).
I have already placed an order for the motors and will update you guys on the progress.
Cheers
(in reply to AZheli)
       Post #: 184
RE: Walkera 5#10 - 7/16/2008 3:37:24 AM
ausaero
Status: offline
Hello again.
I received my new motors yesterday and hurried home to fit them. Unfortunately, I found out the the problem all along was not
the motors but the 4-1. I must have busted the upper motor controller during the crash. It was working intermittently yesterday
after the install, then it just deteriorated until it was no longer giving power to the motor(Upper).
I reckon, the reason why the heli wont go any higher than 1 ft off the ground was because I was not getting enough lift due to
the very minimal power being supplied by the 4-1 to the motors.
Anyway, my 5-10 is grounded at the moment because my supplier does not have the receiver in stock.
Would any one know if the HM5G4Q3 2.4Ghz Receiver (PN HM-5G4Q3-Z-22 Receiver (RX-2411)) would work on the HM5-10?
Cheers.
       Post #: 185
RE: Walkera 5#10 - 7/16/2008 6:17:38 AM
Tedstrickland
Status: offline
The 5#10 uses the 2401 rx. I wouldn't try anything but an OEM replacement. I would recommend you buy another 5#10, and use it for parts. The cost to build a 5#10, strictly from individual parts is about $350 USD, so buying a scond unit is a far cheaper way to go. IMHO, you will probably use virtually all of it .......eventually. The only "spare parts" I would have on hand are the blades, extra batteries, maybe a vertical skid and a canopy or two. I have done 25 or so flights in the past few days, and the only parts I broke are the OEM landing gear, which I quickly replaced witth the SuperSkids 400. I am waiting for the Exceed Blazing Star skids to arrive, as recommended by another post.... Good Luck and Happy Flying. Ted
       Post #: 186
RE: Walkera 5#10 - 7/16/2008 9:23:23 AM
msdavid
Status: offline
quote:
ORIGINAL: msdavid
On my 19th fly my receiver burned, apparently is a known issue with the Blade CX2 controller.
So I tried a new thing: Used a Spectrum AR6100 Receiver, a futaba G190 gyro and two Skyborne 7A ESCs.
The trick was creating the right rudder/throttle mixing but after failures and more failure, I got it flying awesome.
It flies like never, I have some really cool mixing programs for landing, aleiron imput etc. I am very Happy with the resault.
And BTW, now I can use the standard 1S battery.
I am making this PM public in case anyone else needs this in the future.
quote:
I'm really interested in how the receiver and esc's are wired. I've got a HM5 #10 and a spare receiver just like the one you used that came with my DX6. I would like to fly the little coax with the same radio I use for my other helis. Let me know.
*4CH coaxial fixed pitch helicopter diagram*
Please note that the right rudder/throttle mixing is required for this to work
Click to see fullsize image.
Click for fullsize
(in reply to msdavid)
       Post #: 187
RE: Walkera 5#10 - 7/18/2008 10:17:14 PM
rogerwack
Status: offline
I just received my 5#10 a week ago,and I must say after owning several e-sky heli,there is no comparrison!
Although the 5#10 is fairly stable for the first 60 seconds of flight on a 90 minute charge,it rapidly deteriorates, needing constant trimming while in flight! which only lasts a mere 3 minutes tops!
Compared to the Lama v3 and v4 both of which I have flown alot,and that were almost half the cost,I must say the E-sky Lama 3 and v4 blows this bird away IMO.
What I would like to know is there a battery upgrade for the 5#10 so I can get more than 3 min flight time?
       Post #: 188
RE: Walkera 5#10 - 7/19/2008 7:09:42 AM
RavenC
Status: offline
