mr.chomper
I'm having tons of fun with this bird but it's also a money pit, mostly due to the fact that I'm a wreckless flyer. My balance bar is bent and she vibrates a lot now, I've got replacements on order. If you want to see this thing fly fast (really fast) then take the weights off the balance bar, it isn't uncontrollable but it is really responsive. I've put the weights back on because I'm not smooth enough with the controls to deal with how fast it moves when the weights are off, but if you are an experienced pilot you should give it a go, its a blast. BTW the 180 motor heat sinks fit and do a good job of cooling the motors. You can get 2 heat sinks on the front motor but I think you can only fit one on the rear motor. So far I've broken: 1 canopy 1 set of blades 1 rotor gear (chewed up when motor backed out, make sure your motors are screwed in nice and tight) 1 balance bar (bent, but not totally wasted) 1 stock skids (replaced with super skids) 1 rear prop blade (I'm just going to remove it, though I have a replacement on order). I fly like a mad man and I lack patience, but I'm learning that I need it because most of my crashes have been avoidable. After reading this and other threads I will consider dropping in a lama "4 in 1" and battery to reap the rewards of the lama's better gyro. Not that I have a problem with my stock 4-in-1 but I'm using this heli as a stepping stone to a single rotor FP and I want to get used to messing with the electronics too. All in all this is a great heli to learn on and a decent platform to modify. I do have an issue, which is likely due to one of my gears being a little warn, that is when I spin the heli in one direction it goes up... when I spin it in the opposite direction it goes down. If the replacing the gear doesn't resolve the issue I'll have to look at adjusting whatever settings the 4-in-1 allows me to adjust (it may only be gyro gain). Either way if anyone has some words of wisdom for what is happening and how to resolve it... help a brother out.
