JoeSnuffie -> RE: Walkera 5#10 (9/30/2008 2:50:38 PM)
quote:
ORIGINAL: ausaero Hi flipside, Looks like people here are having the same problems (ie not having enough lift). If you will go back a few pages from this post you will notice that I had the same problem. I managed to fix mine by removing the motors of the assembly and just running them off load. While doing that, I played around with the sensivity pot on the receiver. At first, the motors where running at different speeds and at times would just not run at all. I got pissed off and started playing around with the pots...And next thing I knew, they were both running at the same speed when I hit the throttle and were also running at high speed. I put them back on and never had the same problem again. You never know mate. Give it a go. You've got nothing to lose. For people like me who raced RC cars before ESC, this is very familiar. The POTs may get 'burned' and a slight turn could fix this by making contact on a part that isn't 'burned'. Another broblem I found is that the upper gear, the one attached to the lower blades, loses connection with the shaft. There are two screws that should rest in recesses in the shaft to hold the gear firmly to the shaft. In my case, I was hotdogging it around the living room and hit a wall. After this the heli didn't have the power to get off the ground. The motors would not spin with the speed they had, before. Full right rodder did cause it to spin faster, it a wild circle on the ground. The reason was that the impact stripped the hole where the esrews are and they backed out a little - just enough to allow the gear to slip a little around the shaft. I noticed this by hand turning the blades and watching the gear sit still. I replaced the two tiny screws with 2 very slightly larger ones and everything is working well. I would also like to note that in this same crash, I broke the receiver crystal. Never, in more than 8 years of RC Cars and 3 of helis, have I broken a crystal. I didn't even think it was possible. There are no external marks, nothing is loose, and I can't hear anything rattle. Thankfully I have several sets of crystals and just replaced them. The symptom was that the RX light blinked slowly, just as if the TX was off. Just a heads up in case this happens to you. Just a note on getting tiny machine screws . . . I disassemble old CD Roms, Floppy Drives, Tape Drives, etc., forthe screws. There are many tiny screws in these devices and you will eventually find a use for them if you stay in this hobby. Also, one more bit of info. My skids broke within a week and I fiberglassed them by taking short segments of fiberglass thread and crazy glue. I reinforced the 2 supports that hadn't broken, as well. This lasted for another 2 weeks. Yesterday, my Kydex arrived and I made some skids from it. It's really very easy to do and will never break. I'll take pictures, this evening, and post them.
