Lunchboxer
MA, USA Status: offline
Description from Kyosho's website: Roll over any terrain with this fully functioning electric tracked machine! Easy to operate electric vehicle cruises up steep slopes and easily rolls over gaps as it powers across the rough surfaces and etches its track marks in snowfields, sand and dirt piles. Kyosho has reproduced the distinctive “DF300” from Japan’s major tracked vehicle manufacturer, Ohara Corporation. The sophisticated mechanics of the motor control features a combination bevel gear and brake control system that produces forward, reverse, left/right turning and also pivoting (the Blizzard can turn in its own tracks) for fully operational tracked vehicle control. And all the main components are pre-assembled so only a short time is needed for the finishing touches. Only a true tracked vehicle can back-up your go-anywhere spirit and be enjoyed anywhere you want to take it! Reproduction of Ohara Corporation’s distinctive DF-300. Sophisticated control mechanism features combination bevel gear and brake control system. Able to turn left/right and also turn in its own tracks, just like a real tracked vehicle. Equipped with suspension system with springs on all wheels. Features a rotary speed controller with 3 forward speeds and 1 reverse. Includes high-power 540-class motor. Main components are pre-assembled.
_____________________________
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
