RE: LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Unusual R/C >> RE: LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: LB Getting Ready for SNOW - Kyosho EP Bli... - 12/10/2007 3:32:50 PM
Lunchboxer
Status: offline
Yeah, I am too lazy.. so I just went with whatever the thing that guys at Making Trax are using!
_____________________________
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
(in reply to Yub, yub, cmdr!)
       Post #: 251
RE: LB Getting Ready for SNOW - Kyosho EP Bli... - 12/10/2007 3:39:27 PM
Lunchboxer
Status: offline
Time to put in some ballbearings..
While the wheel was out, snapped a pic of the suspension setup.. pretty simple, huh?!
Click to see fullsize image.
Click for fullsize
(in reply to Lunchboxer)
       Post #: 252
RE: LB Getting Ready for SNOW - Kyosho EP Bli... - 12/10/2007 3:44:19 PM
Lunchboxer
Status: offline
Standard wheel...
Click for fullsize
       Post #: 253
RE: LB Getting Ready for SNOW - Kyosho EP Bli... - 12/10/2007 3:47:41 PM
Lunchboxer
Status: offline
Not even metal bushings!! Just plastic!!
Click for fullsize
       Post #: 254
RE: LB Getting Ready for SNOW - Kyosho EP Bli... - 12/10/2007 3:52:00 PM
Lunchboxer
Status: offline
MUCH BETTER!!
Click for fullsize
       Post #: 255
RE: LB Getting Ready for SNOW - Kyosho EP Bli... - 12/10/2007 3:53:55 PM
Lunchboxer
Status: offline
Interesting rear suspension setup! You can put in a spring and adjust the collar to increase the travel... Maybe later!
Click for fullsize
Click for fullsize
       Post #: 256
RE: LB Getting Ready for SNOW - Kyosho EP Bli... - 12/10/2007 3:56:27 PM
Lunchboxer
Status: offline
So this is how the track are connected together...
Click for fullsize
       Post #: 257
RE: LB Getting Ready for SNOW - Kyosho EP Bli... - 12/10/2007 3:58:59 PM
Lunchboxer
Status: offline
Don't like the design here.. The driving wheel and chain driven wheel assembly rides on the shaft, with no bushings, so no option of changing to ballbearings!
I think I will apply some heavy grease and then clean it off on the outside (so it doesn't attract dirt..)..
They should have gone w/ a better design here!
Click for fullsize
       Post #: 258
RE: LB Getting Ready for SNOW - Kyosho EP Bl... - 12/10/2007 5:21:15 PM
SS Pede
Status: offline
I have thought about getting a Blizzard in the past. I love the scale body of this new DF-300 model! I wish Kyosho still made a plow for it! The DF-300 would be so sweet with a plow and a set of RAM R/C flashing lights!
       Post #: 259
RE: LB Getting Ready for SNOW - Kyosho EP Bl... - 12/10/2007 5:28:15 PM
Lunchboxer
Status: offline
Yeah, I am thinking about a flashing light unit myself.. we will see... ha! I like to get the mechanical aspect sorted out first before doing other stuff!
(in reply to SS Pede)
       Post #: 260
RE: LB Getting Ready for SNOW - Kyosho EP Bli... - 12/10/2007 5:34:17 PM
B44&501xRacerEX
Status: offline
quote:
ORIGINAL: Lunchboxer
Sorry, LB?
Well, time for a custom mod then to run the bearings, take a drill and cut you some slots for ball bearings, if you want..
B44 FT/Tamiya 501x "WCE"/HPI E-firestorm/Yokomo YR4 M2/Losi DT/F-150/Blackfoot Xtreme/Twin Force/TXT-1
       Post #: 261
RE: LB Getting Ready for SNOW - Kyosho EP Bl... - 12/10/2007 5:42:16 PM
Lunchboxer
Status: offline
Then the shaft will be too small in diameter and might not be rigid enough...
We will see.. stock for now.. will think of a better solution later.. maybe someone will make aluminum drive wheels w/ bearings?! I'd buy that!!
(in reply to B44&501xRacerEX)
       Post #: 262
RE: LB Getting Ready for SNOW - Kyosho EP Bl... - 12/10/2007 6:08:31 PM
B44&501xRacerEX
Status: offline
I hope it does have aftermarket parts. That a way you can upgrade some of those parts to Aluminum.
       Post #: 263
RE: LB Getting Ready for SNOW - Kyosho EP Bl... - 12/10/2007 6:11:32 PM
Lunchboxer
Status: offline
I am not counting on it.. I highly doubt that there's aftermarket for this thing.. (not enough people buying them..) Too bad, really! I wish Kyosho would release some itself!
