B44&501xRacerEX
Joined: 2/26/2007 From: Owensboro, KY, USA Status: offline
quote:
ORIGINAL: coleholley quote:
ORIGINAL: zjwhitrock how do you think a ep blizzard would handel with the stock electronics and moter out of a stampeed xl 5? i figerd i could buy the blizzard, used stampeed with venom 4000 battery and a charger for under $300 The blizzard will handle the XL-5 stuff fine. I run the same set-up. Also I'm running the XL-5 motor now too, just not in the picture here. I had a lot of glitching once i put my XL-5 stuff in, and couldn't fix it, so I stopped using it for a while, then when we got snow I went and tryed it and it worked great. How do you guys run it in snow with non-protected electronics....is the body water-proof enough to not let water in?
_____________________________
B44 FT/Tamiya 501x "WCE"/HPI E-firestorm/Yokomo YR4 M2/Losi DT/F-150/Blackfoot Xtreme/Twin Force/TXT-1
