RE: LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Unusual R/C >> RE: LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
Page: <<   < prev  39 40 [41] 42 43 44 45 46 47 48   next >   >>
Login
RE: LB Getting Re... - 3/21/2008 12:49:50 AM
nomobux
Status: online
quote:
ORIGINAL: AlphaDOG
Do I can use this : Traxxas Titan 550 Motor 12T ? My DF-300 EP got one LRP A.I. Automatic Runner Plus Reverse ( ESC ) I know it support only 15T + motor but I have read somewhere I can use it this motor without problem because a 550 size motor its like a 540 size 14 - 15T ... and I think im going to use 22 - 23T pinion with the stock spur gear 86T.
Hopefully an electronic expert will chime in.
< Message edited by nomobux -- 3/21/2008 12:51:46 AM >
_____________________________
" I GOTTS NOMOBUX "
(in reply to AlphaDOG)
       Post #: 1001
RE: LB Getting Re... - 3/21/2008 4:11:52 AM
alaskadf300
Status: offline
The best course of action is to contact the manufacturer of the ESC.
Summer-Tamiya Lunchbox/Winter-Kyosho Blizzard/Indoors-micro baja/Shelf-Tamiya Rough Rider
(in reply to nomobux)
       Post #: 1002
RE: LB Getting Re... - 3/21/2008 4:24:54 AM
Kaz the Minotaur
Status: offline
I have an old 775 size motor out of a cordless drill...I think that would make an interesting candidate for the Bliz. I'll bet you could put a huge pinion on it!
(in reply to alaskadf300)
       Post #: 1003
RE: LB Getting Re... - 3/22/2008 11:32:12 PM
Lunchboxer
Status: online
That is indeed the case, BUT, then you are assuming that the LRP Runner Plus can truely handle a 15T motor!
It probably can, but just saying all motors are different.. the "turn limit" is really just a guideline.. a silvercan is 27T.. a stock racing motor is 27T.. and clearly the 2 pulls different current...
You can probably give it a try although I'd think it is cutting too close for comfort for me..
quote:
ORIGINAL: AlphaDOG
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
       Post #: 1004
RE: LB Getting Re... - 3/23/2008 12:18:09 AM
Kaz the Minotaur
Status: offline
Finally got mine running...for a few minutes. It isn't as clean as come other installs but it will do.
I kept loosing the tracks. Is there a was to tighten them up so they don't slip off as easily? Then the track ripped. Is it easy to find new ones?
The steering needs work also. Just the slightest touch makes a big change in direction.
Where is a good place to get parts from? Ultimate Hobbies doesn't have much of a selection.
< Message edited by Kaz the Minotaur -- 3/23/2008 12:32:44 AM >
(in reply to Lunchboxer)
       Post #: 1005
RE: LB Getting Re... - 3/23/2008 1:42:20 AM
nomobux
Status: online
quote:
ORIGINAL: Kaz the Minotaur
Last I saw, Ultimate showed tracks. Combo of brake pads and the 100,000 diff fluid settles down the steeering , etc. I can send you the fairly lame directions for the DF. Install doesn't look that bad, after all you're testing. Track breakage might be an age thing too. It's that damn Lipo and big motor .. lol
< Message edited by nomobux -- 3/23/2008 1:46:16 AM >
" I GOTTS NOMOBUX "
(in reply to Kaz the Minotaur)
       Post #: 1006
RE: LB Getting R... - 3/23/2008 1:47:31 AM
alaskadf300
Status: offline
Youch!, that's truly lame, the old style tracks are reputed to have pliability problems. It looks as if they had a lot of miles already as well. I would just get a set of Kyosho #BL10B and slap those on. I have bad news to report.....some "hung like a hamster" hacker has killed the Making-Trax forum, punks!.
       Post #: 1007
RE: LB Getting Re... - 3/23/2008 1:50:07 AM
Kaz the Minotaur
Status: offline
I checked and they don't. Kyosho has some though.
So doing the brakes pads makes them not as grabby? What about using wheel bearing grease?
Is there a way to adjust the tracks though?
That must be why I couldn't post there the other day then.
< Message edited by Kaz the Minotaur -- 3/23/2008 1:52:23 AM >
       Post #: 1008
RE: LB Getting R... - 3/23/2008 1:52:04 AM
nomobux
Status: online
quote:
ORIGINAL: alaskadf300
[/quote
How in the hell did they do that and when ? I was there a day or so ago
" I GOTTS NOMOBUX "
       Post #: 1009
RE: LB Getting Re... - 3/23/2008 1:56:02 AM
nomobux
Status: online
Yes , although I'm not real sure on an older one ( but it must be the same ) look real close at the end and see where you loosen a couple of screws on the side and slide the axle back a bit
" I GOTTS NOMOBUX "
       Post #: 1010
RE: LB Getting R... - 3/23/2008 1:58:23 AM
alaskadf300
Status: offline
I don't know how, but it must have been only a few hours ago, I was on there this morning. There is a lot of valuable Blizzard information, hopefully it can be saved.
       Post #: 1011
RE: LB Getting Re... - 3/23/2008 1:59:07 AM
nomobux
Status: online
i was just at makin trax and it appears to work ????????????
" I GOTTS NOMOBUX "
       Post #: 1012
RE: LB Getting Re... - 3/23/2008 2:02:33 AM
Kaz the Minotaur
Status: offline
It looks as if the rear most roller can be adjusted forward and backwards. Looks as if that would tighten the treads up.
       Post #: 1013
RE: LB Getting Re... - 3/23/2008 2:05:01 AM
nomobux
Status: online
The axle should slide on both sides
" I GOTTS NOMOBUX "
       Post #: 1014
