alaskadf300
AK, USA Status: offline
I'm thrilled, except I need to remove the brake setting. It needs to be Forward/Neutral/Reverse, right now it's set at 50% brake, and it does cart-wheels if I let go of the trigger too quick. One thing I wanted to know was how well would it jump, the answer is perfectly, it got nearly two feet of air several times and just kept going. The CG/balance is lowsy for climbing, but just right for high-speed jumps. I'm leaving the suspension alone, it's actually right on for crusty/hard snow landings. The brakes are less twitchy after I adjusted them, but only 60% ideal, Dupont Delrin pads should fix that.
_____________________________
Summer-Tamiya Lunchbox/Winter-Kyosho Blizzard/Indoors-micro baja/Shelf-Tamiya Rough Rider
