RE: LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Unusual R/C >> RE: LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
Page: <<   < prev  44 45 [46] 47 48 49 50 51 52 53   next >   >>
Login
RE: LB Getti... - 5/12/2008 8:56:41 PM
nomobux
Status: offline
Yeh , Prob the batt. I run 3800s and 4200s. Even with the brushless .. very long run times. Mite have to do lites for next winter. Nights on the snow would be neat and orient yourself betta
_____________________________
" I GOTTS NOMOBUX "
(in reply to brel)
       Post #: 1126
RE: LB Getti... - 5/13/2008 10:17:31 AM
brel
Status: offline
I ran the blizzard in the back yard last night, (where the light from the street lights don't shine (very dark)) and it looked awe sum with the lights on in the dark, I am thinking about adding some big LED spot lights to the front as well (like on a rally car) and maybe changing to a four channel radio set to turn the spot lights on and off also thinking about adding either a plough or a winch if not both ( I saw an item about modifying a servo with the stop removed so that it will turn under control of the stick, but I cannot remember where I saw the item.)
(in reply to nomobux)
       Post #: 1127
RE: LB Getti... - 5/13/2008 10:42:23 AM
nomobux
Status: offline
They also sell the servo modded somewhere. Go to RCCrawler site and do a search or maybe check in the scale section.
" I GOTTS NOMOBUX "
(in reply to brel)
       Post #: 1128
RE: LB Getti... - 5/13/2008 10:46:18 AM
nomobux
Status: offline
Just looked. Go to the RCCrawler and search ... servo winch ... lots there on how, etc. Let me know if a prob.
" I GOTTS NOMOBUX "
       Post #: 1129
RE: LB Getti... - 5/13/2008 10:48:50 AM
brel
Status: offline
quote:
ORIGINAL: nomobux
thanks for the link
Rock crawlers now there's a thought of another direction to go in rc, if I get bored of tracked vehicles
< Message edited by brel -- 5/13/2008 11:14:19 AM >
       Post #: 1130
RE: LB Gett... - 5/13/2008 5:52:11 PM
jimbiss
Status: offline
http://rccrawler.com/forum/showthread.php?t=17970
here is one of the better threads on winches.
(in reply to brel)
       Post #: 1131
RE: LB Gett... - 5/13/2008 6:45:35 PM
brel
Status: offline
thanks guys I did a Search on google with "rc servo winch" and found a similar article on servo winches
here is a link to the article
http://ukrcrc.com/site/index.php?option=com_content&task=view&id=27&Itemid=43
(in reply to jimbiss)
       Post #: 1132
RE: LB Gett... - 5/13/2008 8:33:24 PM
brel
Status: offline
Hi a couple of pictures of the set up of the blizzard, as of 1800 hrs. BST. When I get the ESC this will all be changed with the micro switch, the throttle servo, resistor and the manual speed control unit will be removed in favour of the ESC
1, lights control box
2, steering servo
3, speed resistor
4, throttle servo
5, lights battery PP3 rechargeable 8.4 Volts
6, Receiver and servo batteries 4X AA size 6 Volts
7, Receiver and servo power switch
8, lights power switch
9, brake light micro switch
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by brel -- 5/13/2008 8:41:01 PM >
(in reply to brel)
       Post #: 1133
RE: LB Gett... - 5/13/2008 8:58:29 PM
nomobux
Status: offline
quote:
ORIGINAL: brel
2, steering servo
3, speed resistor
4, throttle servo
Gettin kinda crowded in there. Don't think it would care for snow (lol). Aren't you using a stick pack for your main power ?
" I GOTTS NOMOBUX "
(in reply to brel)
       Post #: 1134
RE: LB Gett... - 5/13/2008 10:07:35 PM
brel
Status: offline
Hi I am using these for my running power but when I get the ESC the four AA batteries and the holder will be removed along with the speed controller and it's servo, resistor and micro switch , the yellow pack is from the heng long tiger and is crap the black two are 1200mAH and are twelve years old and they are starting to lose form, the two carson packs are 2300mAH that give me a good run and are less than two months old
Click for fullsize
< Message edited by brel -- 5/13/2008 10:22:49 PM >
       Post #: 1135
RE: LB Gett... - 5/14/2008 2:42:16 PM
brel
Status: offline
I have bought A ripmax pro peak charger so hopefully it should sort out any battery problems that I have
(in reply to brel)
       Post #: 1136
RE: LB Gett... - 5/14/2008 6:32:30 PM
nomobux
Status: offline
Just wait. The need for speed will rear it's ugly head. Then it's a Sidewinder 4600 or 5700 combo. They are great.
" I GOTTS NOMOBUX "
(in reply to brel)
       Post #: 1137
RE: LB Gett... - 5/16/2008 8:41:57 PM
brel
Status: offline
I have bought some Spot lights Like the ones you see on rally cars and I am going to fit them to the front of the blizzard on the chassis below the cab so I will have to make a bracket to fit them.
       Post #: 1138
RE: LB Gett... - 5/17/2008 3:30:27 PM
