nomobux
Joined: 2/21/2005 From: Ellensburg, WA, USA Status: offline
quote:
ORIGINAL: brel Nomobux, I got another month before my trip to Cornwall on vacation, but here are a couple of pictures of the heat sink and fan fitted, What make is the strobe bar that you have fitted and where did you get it from. it definitely looks better than the one that came with the blizzard Fan and sink looks good. The bar is fom Tower ... Ram .. http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=000897484&I=LXDZ75&P=K I don't do electronics too well, so I went this route. A bit spendy. What I did was mount it all in the cab ( lite, wires, control board ) cut the power leeads and put a plug in. I can remove the cab and unplug .. easy as far as taking the body off. If a guy was into doing this stuff, I'm sure you could do it cheaply.
_____________________________
" I GOTTS NOMOBUX "
