RE: LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Unusual R/C >> RE: LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
Page: <<   < prev  48 49 50 51 [52] 53 54 55 56 57   next >   >>
Login
RE: LB... - 8/30/2008 2:02:18 PM
nomobux
Status: offline
quote:
ORIGINAL: brel
alphadog, you can change ALL of the bushes in the diff to ball races
X2 All bearings and go with 100K
_____________________________
" I GOTTS NOMOBUX "
(in reply to brel)
       Post #: 1276
RE: LB... - 8/30/2008 4:25:21 PM
Lunchboxer
Status: offline
I changed all the bushings out to ballbearings..
The diff fluid is really there to increase resistence between the left and right side output shafts.. so they will tend to spin at the same speed more easily.. what this would do is allow you to go straight and when you want to turn, the brake will need to apply some force to turn the thing.. so give you better modulation..
quote:
ORIGINAL: AlphaDOG
do I need absolutely 100,000k diff fluid ? I filled up mine with only 10,000k from team associated and I still waiting for see if someting leak ... whats the diff fluid help does it give more traction , more speed , more punch ? does it reduce runtime ? or give more runtime ?
and guys take a look on this pictures
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
(in reply to AlphaDOG)
       Post #: 1277
RE: LB... - 8/30/2008 10:31:00 PM
AlphaDOG
Status: offline
which kind of BB will go in the gear box center ? in my package no one will fit ... I got one it sit in the gear box center hole but I cant put the diff output shaft into it ... the hole of the bearing are too small...
http://www.rcbunker.com/ : GO AND UPLOAD VIDEOS OF YOUR DRUG !!!
(in reply to Lunchboxer)
       Post #: 1278
RE: L... - 8/31/2008 5:57:14 AM
Lunchboxer
Status: offline
You probably didn't read the thread.. I think I had the same problem.. and turned out that there's bushings on the diff output shafts that you can remove.. I think I posted it somewhere.. ha!
       Post #: 1279
RE: L... - 9/1/2008 12:43:19 AM
AlphaDOG
Status: offline
ok I removed this 2 bushing on the output drive of the diff and now I dont see any bearing would fit into it so I dont need to put bearing on it just throw 2 bearings in the gear box center on each side and put the diff direct into this ? without any bushing on it ( diff output drive ) ?
       Post #: 1280
RE: L... - 9/1/2008 12:55:04 AM
Lunchboxer
Status: offline
Please see Post #281 of this thread and see if that helps you...
       Post #: 1281
RE: L... - 9/1/2008 1:06:06 AM
AlphaDOG
Status: offline
yeah I have seen it but sorry im not really english so I dont understand fine ... on this picture on the Post #281 the first bushing at left it this one I talk do I can only just remove them both from the diff and run it without this ... ?
       Post #: 1282
RE: L... - 9/1/2008 1:09:15 AM
Lunchboxer
Status: offline
The 2 bushings on the left of that pic are replaced by a single ballbearing... (the one on the right!)
       Post #: 1283
RE: L... - 9/1/2008 1:21:51 AM
AlphaDOG
Status: offline
take a look on this 2 bushing going on the diff output drive I said do I can remove this 2 bushing and put the diff in the plastic gear box without put this 2 bushing ?
       Post #: 1284
RE: L... - 9/1/2008 2:19:12 AM
Lunchboxer
Status: offline
Yes, as post #281 shows, the 2 bushings are replaced by one single ballbearing...
       Post #: 1285
RE: L... - 9/1/2008 2:31:38 AM
AlphaDOG
Status: offline
hmm ok like this I think
       Post #: 1286
RE: L... - 9/1/2008 2:33:51 AM
AlphaDOG
Status: offline
this 2 bushing where replaced by 2 big blue shielded bearings at the right of your picture @ post #281
       Post #: 1287
RE: L... - 9/1/2008 4:15:24 PM
AlphaDOG
Status: offline
before I put 10,000 associated silicone diff fluid whats if can do more or less then the 100,000 ?
       Post #: 1288
RE: L... - 9/1/2008 4:56:19 PM
nomobux
Status: offline
The 100K is pretty well proven to work. Stay close to that figure, if possible
" I GOTTS NOMOBUX "
       Post #: 1289
