RE: LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Unusual R/C >> RE: LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
Page: <<   < prev  48 49 50 51 52 53 [54] 55 56 57   next >   >>
Login
RE: ... - 10/6/2008 3:07:36 PM
Lunchboxer
Status: offline
Yours has a completely different setup... the brakes on the newer Blizzards are used to slow down / stop the driveshaft on each side of the differential to create the steering effect.. take a look at the build thread and you will see what I meant!
_____________________________
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
(in reply to warheadforever)
       Post #: 1326
RE: ... - 10/6/2008 3:33:49 PM
warheadforever
Status: offline
O.K. LOL I will do so now.
I have God, Guns, and southern pride!
May you grass be green, and your tides be high forever.
(in reply to Lunchboxer)
       Post #: 1327
RE: ... - 10/13/2008 5:28:46 PM
nomobux
Status: offline
Well, I'm ready to light up the night. Pics don't show too good, but they are bright. Headlites, foglights, tail, emergency and spot. Can't say I'm ready for cold and snow tho.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
" I GOTTS NOMOBUX "
       Post #: 1328
RE: ... - 10/13/2008 5:34:39 PM
Lunchboxer
Status: offline
The light setup looks great!!
(in reply to nomobux)
       Post #: 1329
RE: ... - 10/13/2008 5:43:30 PM
nomobux
Status: offline
quote:
ORIGINAL: Lunchboxer
Thanx LB. Can't say I'd do it again .. kinda a PITA. Too small a space or too big a mitts ... lol
" I GOTTS NOMOBUX "
       Post #: 1330
RE: ... - 10/13/2008 5:54:41 PM
Lunchboxer
Status: offline
I hear you! Ever thought about just using the BEC to power the lights? Then you don't need the 9V battery there.. or it is too low? Or maybe just use the 7.2V directly.. that should be enough to power up the LEDs if it needs the voltage, right?!
       Post #: 1331
RE: ... - 10/13/2008 8:08:31 PM
brel
Status: offline
Just been giving my blizzard a service
thus far, an oil change in the diff removed the diff and cleaned the grease out of it and put some 1,000 high viscosity silicone diff oil in the centre and silicone grease on the spur gear to try and keep the oil in the centre where the bevel gears are.
new brake pads from gasket material
general wash and brush up
recharged the running lights batteries
took all of the ball races out of the wheels and soaked them in a thick oil (warmed up to make it penetrate better) to make sure that they are lubed and water tight
I use the 7.2v running batteries on my tanks so the are cycled all of the time
< Message edited by brel -- 10/14/2008 12:30:49 AM >
       Post #: 1332
RE: ... - 10/13/2008 8:11:52 PM
Lunchboxer
Status: offline
Looks like we are all getting our Blizzards ready for the winter, eh?!
(in reply to brel)
       Post #: 1333
RE: ... - 10/14/2008 11:06:27 AM
brel
Status: offline
partially getting ready for winter also it was running more to one side so I decided to clean and re oil the diff
       Post #: 1334
RE: ... - 10/19/2008 8:14:58 PM
773W
Status: offline
Ya, mine has been sitting all year since the snow left. Took out the Rx and servo for one of my other rides. Cant believe this tread is stil going. Way to keep on keeping on guys!!!Got big plans for the blizzard this winter, going brushless!!
Racing is a sport......Building and fixing are hobbys.
(in reply to brel)
       Post #: 1335
RE: ... - 11/6/2008 12:07:59 AM
lee172
Status: offline
54 pages.... sheeesh! and its not even a 'proper' build!
i clean forgot about this thread, because its out of the way in the unusual forum..
mine is still firmly NIB...
47 NIB and TA-03R/S TRF, F-103LM, M-04L, DF-01 as runners..
FF-01, Volvo 1/14 being built
(in reply to 773W)
       Post #: 1336
RE: ... - 11/6/2008 1:19:27 PM
Lunchboxer
Status: offline
You need to "build" it up, Lee!!
I ended up taking almost everything apart anyway... so it was kind of a build thread.. ha!!
(in reply to lee172)
       Post #: 1337
RE: ... - 11/6/2008 3:40:06 PM
nomobux
Status: offline
It's raining white WaWa here now
" I GOTTS NOMOBUX "
       Post #: 1338
RE: ... - 11/6/2008 3:43:00 PM
jimbiss
Status: offline
We had like 1/2 inch of snow yesterday. So it will be here soon. Guess I better get those bearings in there soon, haha.
       Post #: 1339
RE: ... - 11/6/2008 3:48:20 PM
