What scale do you use to balance your blades?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> What scale do you use to balance your blades?
Page: [1]
Login
What scale do you use to balance your blades? - 11/29/2007 7:45:25 PM
MMatheny
Status: offline
And what did it cost and where did you get it?
Also, what range do I need?
< Message edited by MMatheny -- 11/29/2007 7:51:24 PM >
_____________________________
Mike
"Never use your shins as a blade tracking device" - Mike
       Post #: 1
RE: What scale do you use to balance your blades? - 11/29/2007 8:18:41 PM
123Splat
Status: offline
Dont use a scale. Use a prism as a fulcrum. ended up being easier than using a RCBS powder scale to weigh each blade and then try to match.
Besides, it isn't only the weight difference in the blades, MOSTLY, it's the balance of the 'center of balance' of each blade. Trimming one blade to match the weight of the other, without knowing where to trim to move the center of balance, won't do the job. That's why the standard process is the reverse: add minute weights to the lighter blade, at a specific point, to move it's new COB to the approx same point as on the other blade, while bringing the weight up to match (again, approx,, close as you can get).
It's not the takeoff or the flying, it's the landing and repairing, so I can takeoff and fly again...
(in reply to MMatheny)
       Post #: 2
RE: What scale do you use to balance your blades? - 11/30/2007 12:20:06 AM
Shadow99
Status: offline
Matt,
I use the procedure from the Helihobby site: Balencing Blades
and I use the razor-blade method, and it seems to work fine.
Rick
"Growing older is MANDATORY... Growing up is OPTIONAL!"
       Post #: 3
RE: What scale do you use to balance your blades? - 11/30/2007 1:07:14 AM
osterizer
Status: offline
I have a couple of inexpensive digital scales I got from HeliDirect. I do both-- fulcrum for spanwise balance, then static balance by applying tape to match the weights, at the position that will match the spanwise balance. Works very well.
(in reply to Shadow99)
       Post #: 4
RE: What scale do you use to balance your blades? - 11/30/2007 3:02:47 PM
MMatheny
Status: offline
Is there a special tape you use - how do you apply it?
Mike
(in reply to osterizer)
       Post #: 5
RE: What scale do you use to balance your blades? - 11/30/2007 3:05:05 PM
MMatheny
Status: offline
I just bought one of these yesterday - seemed like a good price.
http://www.wholesale-scales.com/index.php?main_page=product_info&cPath=20&products_id=184
Mike
       Post #: 6
RE: What scale do you use to balance your blades? - 11/30/2007 4:14:14 PM
123Splat
Status: offline
Mike,
The vendors say to use 'Tracking Tape' (available from Tower), but, when I was using wooden blades, I used electrical tape (just pressit on at the indicated points). Switched over to JCS Plastic Blades and haven't had to balance since.
Splat
       Post #: 7
RE: What scale do you use to balance your blades? - 11/30/2007 4:24:47 PM
MMatheny
Status: offline
Where do you put the tape? On the leading edge?
Mike
(in reply to 123Splat)
       Post #: 8
RE: What scale do you use to balance your blades? - 11/30/2007 6:01:47 PM
HelisRule
Status: offline
I cut two equal lengths of different colored electrical tape and wrapped them completely around the blades, about a half inch in from the tip I think (I don't have the heli in front of me).
Edited to say, you could always use the decals that came with the Axe. There were some on the sheet meant for this purpose.
< Message edited by HelisRule -- 11/30/2007 6:03:14 PM >
~ HelisRule
- Fly safely - Land softly -
       Post #: 9
RE: What scale do you use to balance your blades? - 11/30/2007 6:30:40 PM
123Splat
Status: offline
Rule,
For balancing, not tracking.
Mike,
I used to cut a long triangle and wrap from under the leading edge, over the top of the leading edge, and on towards the trailing.
I'm not sure that it makes that much diff, as long as you get it on securely ( a little dab of CA or Elmers helps).
(in reply to HelisRule)
       Post #: 10
RE: What scale do you use to balance your blades? - 11/30/2007 6:42:51 PM
MMatheny
Status: offline
BTW, I'm talking about my HDX450 here now - hate to post in this forum, but it is WAY more active than the HDX450 forum?? So, this isn't Axe blades.
Mike
       Post #: 11
RE: What scale do you use to balance your blades? - 11/30/2007 8:18:21 PM
osterizer
Status: offline
Mike-- for balancing, you can use the shiny, clear packing tape that comes in the 2-3" rolls. Easy to apply and doesn't make the blades look horrible.
       Post #: 12
RE: What scale do you use to balance your blades? - 11/30/2007 9:04:40 PM
MMatheny
Status: offline
I'm assuming it doesn't take much then - how close do they need to be? (weight)
Mike
       Post #: 13
RE: What scale do you use to balance your blades? - 12/1/2007 3:00:14 AM
HelisRule
Status: offline
quote:
ORIGINAL: 123Splat
Rule,
Oh, duh. Sorry about that. I guess I lost the topic somewhere along the way.
~ HelisRule
       Post #: 14
RE: What scale do you use to balance your blades? - 12/1/2007 3:10:34 AM
Druss
Status: offline
typically what I do is find the center of balance first, if it isn't right then you add tape to the end of the off blade until the center is at the same point. after this you add tape to the blade that's lighter at the point of center of balance so that you don't throw the center of balance off again until the weights are the same.
       Post #: 15
RE: What scale do you use to balance your blades? - 12/1/2007 3:24:10 AM    <
