bigtim
CA, USA Status: offline
Denny it really depends on how big your plane is,if your glassing a plane then you want to use as little as possable to wet the glass so your not adding too much weight to your model,for glassing models your better off with a model specific product like Z-poxy,or a water based polyurathane,the WB Poly is a easy way to glass needing no catalyst, for hardening/drying as well as low odor. having done my fair share of fiberglass work its smelly messy stuff that can be trouble to work with,if your not totally in control of the material you can turn your model into a brick in no time. the Z-poxy and WB has alot of advantages,I prefer the WB and have had much success using it for 15$ you can get a QT of satin Varathane Diamond finish at Home depot,and save yourself the headache.
