An oddd request
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> An oddd request
Page: [1]
Login
An oddd request - 11/30/2007 12:27:39 AM
Flying freak
Status: offline
Hello
I have an idea that i would like your opinion on.
I currently have a jett 50 FIRE
i would like to do a science fair project that is interesting and id like to do it on airflow and propeller Id like to make a jig to measure thrust and bring tip speed up ABOVE the sound barrier to see if you reach a point where you will no longer produce more thrust no matter how much more power you throw at it
So my Q is what size prop would you use for it and what rpm can i use? im thinking that maybe somthing in the 11X5 would work maybe 11X4?
Steven
       Post #: 1
RE: An oddd request - 11/30/2007 4:39:51 PM
bob27s
Status: offline
Sounds like a well thought out thesis and project
I remember from my science fair days ----- documentation is EVERYTHING... you can never document enough.
Keep good records - even record failures or errors.
More to your point....
If you want to approach sonic tip speeds, you would best not do it with a conventional molded prop. You would run the risk of shattering the blade.
11" diameter = 34.54" circumference * 18,000 rpm = 621720 in/min = 51810 ft/min = 9.8125 miles/min * 60 = 588.75 miles/hr
An 11" prop turning about 18,000 rpm equates to a tip speed around 588 mph
In dry air at sea level with a temperature of 21 °C (70 °F) the speed of sound is 344 m/s (1230 km/h, or 770 mph, or 1130 ft/s)
So the mach number at 18,000 rpm is 588.75/770 = .765
That is approaching M0.8, which is considered where transonic begins - so that is a pretty quick tip speed, and no doubt some airflow over the blade is well exceeding M.8 by a good margin. So you would see some transonic effects and a drop in efficiency.
Why 18,000 rpm here? I do not believe you are going to turn any "usual" 11x4 prop much over 18,000 rpm with a SJ-50, even with a full size nitro pipe properly tunned. Perhaps ya might get up to 18,500.
Mach 1, or a tip speed of 1130 ft/s or 813600 in/min , for the 11" prop requires 813600/34.54 = 23,555 rpm
For your experiment, getting to that M.76 number would be probably useful in showing the performance drop on a curve.
What you would want to do, is use the exact same prop - and use the throttle to set your rpm reference points.
Key here, is you will want to use a carbon fiber prop, just to be safe. There are some available in that size.... you may have to look to Europe, or even look toward some of the CL and FF guys.
One suggestion though.......
You may want to try this experiment with an electric motor.
A few reasons.
1) you are not mechanically RPM limited - Getting to 20,000 rpm with an 11x4 is a matter of AMPS and VOLTS
2) You can measure AMPS and Volts. You know Watts, you can equate/chart the POWER (Watts or HP) needed to turn the prop at that RPM.
3) Electric is smoother - no accelerations - less stress on the blades and prop hub - so you may get away with using a standard blade prop.
4) You can perform the demonstration inside at the science fair without pissing off many people
Anyway.... its a good project !! Stick with it.... and stay safe!
Let me know how you make out.....
Bob
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to Flying freak)
       Post #: 2
RE: An oddd request - 11/30/2007 4:54:13 PM
fizzwater2
Status: offline
If you're going to demo that at the science fair, you might want to consider some sort of lexan or similar safety cage around the prop - wouldn't want that to be the time when the prop gave up the ghost!
no matter where you go, there you are..
(in reply to bob27s)
       Post #: 3
RE: An oddd request - 12/1/2007 4:31:58 PM
Flying freak
Status: offline
I would definitely be aware of the prop arc and most likly would just have it as a static demo with a video ...
bob27 what E motor do you suggest i really don't want to spend allot of $$
also for the motor what would i need for esc/batt anyways to sue a dimmer switch right from an outlet?
< Message edited by Flying freak -- 12/1/2007 4:33:04 PM >
(in reply to fizzwater2)
       Post #: 4
RE: An oddd request - 12/2/2007 4:42:19 AM
Flying freak
Status: offline
Assuming bolly says im good to go for the rpm range what of these props do you recommend and do you know other places to get cf props (other than super cool props they want 110UAD!!!)
Click to see fullsize image.
Click for fullsize
       Post #: 5
RE: An oddd request - 12/3/2007 3:12:49 PM
bob27s
Status: offline
Im probably the worst person to ask for electric motor stuff
But keeping in mind you do not need "flight" hardware, you should be able to locate a DC electric motor that is fairly cheap (ie, big fat and heavy) that will do the job. Im not sure a dimmer switch will handle the current though.
Perhaps ask that one in the electrics forum.... ??
As for props.....
http://pages.prodigy.net/gcleveland_grsmodels/_import/pages.prodigy.net/gcleveland_grsmodels/index6.html
Try Cleveland.. see what they might have.
Also perhaps email Windy.... http://www.windyurtnowski.com/
He may have a few good sources for CL carbon props of the right size.
Also....
You can use good wood props. sometimes those are stronger than all others. Try and find rev-up 11x4 props.
And as long as you are very careful in your testing, and since the prop will not see a flight load, you can probably use the APC prop as well. (You will have to be careful regardless of the prop type and size...)
Bob
Bob Brassell
       Post #: 6
RE: An oddd request - 12/3/2007 4:33:33 PM
Flying freak
Status: offline
Il aks in the electric forum but do you really think apc would be able to take the load if so il try it,
BTW do you Have any suggestions for maybe getting a lexan "tube" made? how think does it have to be i got a friend that ocul probably help me out in making it but how think does it need to be to withstand the force if the prop were to decide to...
im looking into bolly props right now but will see what else i cna come up with the link you gave me (thanx ).
Also im thinking that a cf prop will be able to handle any shock waves better than say wood...
       Post #: 7
RE: An oddd request - 12/3/2007 4:49:59 PM
bob27s
Status: offline
You do not need a tube....
A box is just as good. In fact, it is probably better, and is easier to work with.
You want as much clearance round the blade tips as possible. Do not create something where the tube will affect the airflow over the blade tips in any way (like a ducted fan arrangement).
Wood is an amazing thing.... its been around a long time, and its hard to beat nature sometimes for continuous fibers
Bob Brassell
       Post #: 8
RE: An oddd request - 1/4/2008 1:43:59 AM
Flying freak
Status: offline
This is the rig we came up with only thing left to do would be to mount the scale and tech. We wont ahve any kind of prop protection as i wil be the only one anywhere close to this thing and will alwasy be BEHIND the prop and out of danger (hopefully )
Just a Q for you Bob, Would you be intrested in seeing what numbers (both thrust and rpm) of the differnt props we will be testing (apc 8.8 x 8.5 apc 10 x 6 and bolly 11.25 x 4 CF)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Flying freak -- 1/4/2008 1:46:06 AM >
       Post #: 9
RE: An oddd request - 1/4/2008 3:48:25 PM
bob27s
Status: offline
Nice setup... should work ok.....
Sure, I am always interested in data and information.
Static thrust means only a little, but it is interesting to see sometimes.
Be sure to include all of the variables if possible ..... location, temperature, RH if possible, prop, fuel, and the pipe length. (glow plug to the fat part weld).
Of note, the pipe will tend to keep the rpm fairly consistant, somewhat regardless of the prop. It tends to work like a governor as it attempts to stabilize the system at its natural frequency. Your experiment here may lend some evidence to that aspect. It will be interesting to see.
Bob Brassell
       Post #: 10
RE: An oddd request - 1/4/2008 9:52:22 PM
Flying freak
Status: offline
quote:
ORIGINAL: bob27s
I will do my best to supply all the info i can (when i get the experiment going in by hopefully next week.)
But what is "RH"
What do you mean by the fat part weld? I have never touched the pipe since Dub tuned it for max speed....
Steven
       Post #: 11
RE: An oddd request - 1/7/2008 5:47:06 PM
bob27s
Status: offline
RH is relative humidity. I picked up a cheap digital weather thermometer a few months ago ...... gives pretty good temp and rh info on the display.... I think it cost all of $5.
The "Fat" part of the pipe is the end of the divergent section. You can usually see where the weld line is between the front and rear pieces.
Dub did set it up, but that measurement was not likely recorded. It is important to know the pipe length since it is related the rpm and engine power.
Click for fullsize
Bob Brassell
       Post #: 12
RE: An oddd request - 1/14/2008 3:04:28 AM
Flying freak
Status: offline
RH 65%
Temp -3 C
il get the tuned pipe to you
I had the blue tunned pip connector partially break so that was letting out some gasses that may have brought it down a little...
With 11.25X$ i got 16700 rpm not bad thats 75.8% the speed of sound
btw the engine now has almost NO compression is it time for a new sleeve/piston )
Steven
       Post #: 13
