jstern429
CA, USA Status: offline
Well I guess what I am getting at is that if they are realy using a 43 toothed gear they are custom cutting it. I have a source that I can get the belts and the gear stock and make this myself but the gear stock only comes in specific number of teeth. I can get a 40, 42, 44, but not a 43. Now the stock belt is cut from a wider belt as if you look at the belt it only has half of the part number info on it. So I am just wondering if the same mistake was made on the tooth count and it should realy be 42 or 44. Does anyone have one of these that could post the tooth count and the info on the side of the belt?
