RE: Phase 3 Ef-16 help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> RE: Phase 3 Ef-16 help
Page: <<   < prev  1 [2]
Login
RE: Phase 3 Ef-16 help - 1/3/2008 2:16:39 AM
skyracer068
Status: offline
Use the stock motor with a different speed control. I am running a Castle Creation 35 with a Thunder Power 2200 mah V2 battery and am in the 90 mph range. I never leave home with out this model. Good luck.
Click to see fullsize image.
Click for fullsize
< Message edited by skyracer068 -- 1/3/2008 2:27:00 AM >
(in reply to 71chevydude)
       Post #: 26
RE: Phase 3 Ef-16 help - 1/3/2008 2:18:02 AM
skyracer068
Status: offline
Only the pigeons complain at my local park.
(in reply to wws2010)
       Post #: 27
RE: Phase 3 Ef-16 help - 1/3/2008 2:53:51 AM
f86
Status: offline
Did you use stock set up or did you modify????????????????
(in reply to skyracer068)
       Post #: 28
RE: Phase 3 Ef-16 help - 1/3/2008 7:54:42 PM
skyracer068
Status: offline
I used the stock motor and fan unit but am running a Castle Creations 35 amp speed control. The stock speed control burnt up when I started running a Thunder Power 2200 mah V2 battery. With this set up, you will draw 28 amps continuious with 275 watts for 7 minutes. Good luck.
(in reply to f86)
       Post #: 29
RE: Phase 3 Ef-16 help - 1/3/2008 10:17:08 PM
P. Richards
Status: offline
Excellent tip I just purchased 5 2200 Thunder Power Extreme V2 packs for the f-16 and My Stryker.
P. Richards aka SwatTeam
       Post #: 30
RE: Phase 3 Ef-16 help - 1/4/2008 5:45:32 AM
tuan lam
Status: offline
16--
< Message edited by tuan lam -- 1/12/2008 4:47:35 AM >
       Post #: 31
RE: Phase 3 Ef-16 help - 7/15/2008 10:50:32 AM
kingpin112
Status: offline
I have some 3S-2250mA 18C lipos, weight 191gr. Can i use this in a stock setup or are they too heavy?
(in reply to tuan lam)
       Post #: 32
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU2
