Ed Smith
Joined: 12/29/2001 From: Brantford, ON, CANADA Status: offline
quote:
Ed, I beg to differ, the mathematical speed from RPM and pitch does not take into account the lift (in this case forward motion) generated by the airfoil on the prop. I posted this quite a while back from MAAC magazine, for the same reason our airplanes fly with an airfoil it stands to reason that the airfoil of the prop creating "lift" will propel an airplane faster than the mathematical speed. LGM Graphix, Not so. How one calculates lift and in what units I do not know. As I am sure you are aware the lift, in whatever units, generated by an airfoil is different for different airspeeds. At 2mph will an airplane get off the ground? Gliders lose airspeed and sink to the ground. An engine at idle will not move the airplane along. The weight and drag of the airplane overcomes the forward lift of the prop. This same wieght and drag will also hamper top speed. When using the mathmatical formula certain figures have to be accepted. The pitch of the prop has to be exactly that specified at any rpm, knowing full well that assumption will give optimistic results at certain rpm. For those of us that commonly fly at the speed claimed here, 170mph is no great achievement. The past 30 years of my Pylon Racing has been a 30 year search for more speed. In the later years the claimed speed here is quite common on a Pylon Racing course. I have also found that the mathmatical formula I used is not that far removed from reality. The comments I offer are based on many years of actually doing it, comparing notes with other "Doers" and comparing theory with reality at the speeds we commonly fly at. Ed S
