Razor-RCU
CA, USA Status: offline
Howdy! Actually Dave the Jett-50 on my Patriot was happiest and I got the best performance on the 9x9 APC. I ran a 9x8, and 10x7 also but the 9x9 was clearly superior. It had insane vertical also which is a shock to some when I say 9x9. (It got off the ground in about 110 feet also with that tiny prop.) Went as fast vertical as it did level (it seemed). I have flown Patriots (kits and ARF's, retracts and fixed) with: Irvine-53, K&B-48, ASP-46, Rossi-45, OS-50SX, YS-45, and Webra-50GT. The Jett-50 was a HUGE difference over all the aforementioned. (The YS needed bearings or it mighta been close) I recall the Jett-50 turning a 9x9 APC about 16.5K or thereabouts. I have run and tested a ROssi-53 on the mini-pipe (not full pipe like Speedboy uses) but never got impressive results on 9". Never tried a 9x10 or higher pitch. Cheers!
_____________________________
Revver #5
