Is there really NI CD memory?
Tower Hobbies
Logged in as Guest
  Printable Version
Goldberg Electro Tote - Kit
Seller:  stuk_at_work
Details:   $30.00   |  12/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Is there really NI CD memory?
Page: [1]
Login
Is there really NI CD memory? - 4/4/2003 6:26:45 AM
mike_evader2
Status: offline
In my winter boredom (We have ten centimeters of snow in April- APRIL!!) I did some research on Ni- CD batteries, with some interesting results. It seems that they DO NOT reccommend fully discharging your batteries!
Here's one site i found pretty interesting. http://www.repairfaq.org/ELE/F_NiCd_Battery.html#NICDBATTERY_016
It takes awhile to get through all of the technical ramblings, and is a little old, but it seems pretty good.
       Post #: 1
Where? - 4/4/2003 8:09:07 AM
strato911
Status: offline
Mike - Where in Canada are you? We (Winnipeg) have that forecast (10cm snow), for tonight, and it's coming down pretty strong right now.
Funny you should link to that site - I was there a couple weeks ago! I have seen the "memory effect" often in the past, but sometimes you can give the battery amnesia.
_____________________________
I try to learn from other people's mistakes...
I won't live long enough to make them all myself.
(in reply to mike_evader2)
       Post #: 2
Re: Is there really NI CD memory? - 4/4/2003 10:46:02 PM
mulligan
Status: offline
[QUOTE]Is there really NI CD memory?[/QUOTE]
I can't remember.
       Post #: 3
Is there really NI CD memory? - 4/5/2003 2:03:32 AM
Homebrewer
Status: offline
I believe so. I had a 1100 mah pack that was down to about 650 mah capacity. I cycled the pack 6 times and now it is up to a respectable 1050 mah. Others may disagree but I think that cycyling NICADS is important to alleviate/remedy battery "memory".
       Post #: 4
Is there really NI CD memory? - 4/5/2003 3:08:35 AM
mike_evader2
Status: offline
Im an hour south of Ottawa.. we had 10 cm last night, and a "winter (spring) storm warning" for tonight. Guess im not going outside for awhile...
       Post #: 5
Is there really NI CD memory? - 4/5/2003 4:19:15 AM
strato911
Status: offline
By the time I shovelled my walk today, there was approx 20 cm of fresh snow! That was a pretty big weather pattern. Good thing almost all the old snow had already melted...
       Post #: 6
Is there really NI CD memory? - 4/5/2003 5:22:34 AM
smokingcrater
Status: offline
it isn't much different a couple miles south of you winnipeg... I was out flying in 65 degree weather a couple of days ago, now I am putting the skiis back on with a parka to go flying...
getting off topic... I fly ni-mh's on my glow planes, and li-poly's on the indoor helicopters.
       Post #: 7
Ni- cad memory - 4/5/2003 6:57:35 AM
buchtes
Status: offline
what was that you was asking? I do not know, it's possible I guess.
How about Texas, right now, 8 PM, 75 F, clear sky, make ya wish ya had marker lights on the runway.............................
       Post #: 8
Is there really NI CD memory? - 4/5/2003 7:57:24 AM
sideshow
Status: offline
No...modern nicads do not have a memory.
Homebrewer, nicad "memory" is permanent. If your packs had had a memory there would have been no return.
SR batteries guarantees their packs against having a memory.....ever.
http://www.srbatteries.com/rxpks.htm
Bob
Bob Convery
       Post #: 9
Is there really NI CD memory? - 4/5/2003 8:50:32 AM
strato911
Status: offline
Sideshow Bob - I beg to differ on both counts
- I have had MODERN NiCds develop a "memory" when treated to a bad charging routine. Usually they aren't from RC use though. Like leaving your cordless phone on the charger all the time, or consistantly running them down only a tiny bit (less than 10%) before recharging.
- I have personally revived a few MODERN NiCds exhibiting "memory" problems. It takes a few cycles with moderately aggresive charge rates (C/2 or C) to revive them, and not all of them will return.
       Post #: 10
Is there really NI CD memory? - 4/5/2003 10:36:02 AM
sideshow
Status: offline
*sigh*
Read this....
http://www.repairfaq.org/ELE/F_NiCd_Battery.html#NICDBATTERY_014
Then...read this...
http://www.rcbatteryclinic.com/seminar.htm
Here is an excerpt...
MEMORY OR VOLTAGE DEPRESSION
Contrary to popular belief, the memory effect is not a loss of cell capacity. Memory is a step in the discharge curve of a cell.
See how the voltage of the lower curve is depressed compared with the normal discharge curve that we have seen before? The end result of the step is significant only if a device is designed with too high a cutoff voltage. Most designers take this effect into account and allow for their devices to be run at low enough voltage to avoid this problem. What causes memory? Actually there are two ways to create a step in the voltage profile. One is a precisely repetitive partial discharge followed by a slow full charge. The discharge must be to exactly the same point every discharge in order for this effect to appear. The second and more frequently encountered effect is voltage depression, which is also called memory. This is caused by continuous overcharge at the overnight rate. If a battery is left on slow charge for long periods, the crystals of active material in the plates grow larger. As the crystals grow, the surface area of active material in contact with the electrolyte decreases and this phenomenon manifests itself as a very slight increase in internal resistance, plus a decrease in the open circuit voltage. The voltage step will occur at different times, depending upon how long the overcharge occurs and the temperature of the battery in overcharge. As the overcharge continues, the area of voltage depression will occur earlier in the discharge curve. The area of depression can be removed by one or more discharge/charge cycles, thereby returning the cell's voltage profile to normal. Today’s cell designs have improved to the point where this condition is seldom exhibited.
If after all this (especially that last sentence) you decide that's what you had, then that's what you had.....I guess.
The packs you "revived" had this voltage depression. The packs you couldn't.....were dead (failed).....they didn't have a memory.
Another excerpt:
We generally define failure as the point where the cell fails to yield 80% of its rated capacity. The primary failure mode is the loss of separator integrity that manifests itself in a cell short. This short may be what is termed as a hard short or low resistance or as is typical in onset of failure, the short is of some finite resistance or "soft" short. This soft short causes the battery to "self discharge" in a very short period as well as shunt some of the charging energy during the charge cycle all of which result in what is perceived as a low capacity cell. A functional failure occurs when the cell or battery causes the end-use device to fail to function.
One of the largest (SR), and most respected, battery pack companies guarantees all of it's nicad packs against a "memory". They almost dare you to do it.
If you are able to discharge a pack to exactly the same level every time, or if you are going to continuously overcharge the pack overnight, every night, then worry about it (though it's not really a memory).
Other than that, don't worry about a "memory" and go fly whichever pack makes you comfortable. Right now....I'm trying to make Li give me the warm fuzzy's....almost there!
Bob
< Message edited by sideshow -- Apr 5 2003 5:41AM >
Bob Convery
       Post #: 11
Is there really NI CD memory? - 4/5/2003 12:58:09 PM
strato911
Status: offline
Bob - perhaps you didn't notice, but I was using the term "memory" merely to stick to layman's terms. Yes, I know the technical term is voltage depression, and I have read both of those articles (and more) in depth to try and understand the technology. Your own quote refers to voltage depression as memory:
quote:
... The second and more frequently encountered effect is voltage depression, which is also called memory.
The voltage depression was so bad in some cases, that the pack capacity was measured as less than 10% of it's rating. After 2-4 cycles with pulsed charge rates around C/2 they returned to 105% of their rating. Those I couldn't "revive" came back somewhat, but only to 20% of their rating. The damage was to severe.
Another part of your quote also supports my statement that "memory" (voltage depression) is NOT premanent:
In essence, your own post proved you wrong.
Yes, NiCd's have "memory" (the technical term is voltage depression), and no, "memory" (voltage depression) is not always permanent.
       Post #: 12
Is there really NI CD memory? - 4/5/2003 7:24:35 PM
sfaust
Status: offline
Strato911 sums up my understanding exactly. No, NiCd's don't have 'memory', but do suffer from 'voltage depression'. However everyone seems to call the effects of voltage depression as 'memory'. Thus, whether you call it memory or voltage depression, NiCds suffer from something that temporarily reduces the capacity of the packs when they are not properly maintained. By using cycling, you can reverse this effect in many cases.
No matter what you call it, its there, and described in those references, and many others.
Stephen
       Post #: 13
Is there really NI CD memory? - 4/5/2003 8:33:16 PM
sideshow
Status: offline
This is from SR's website
* Only SR guarantees its cells and packs not to ever form a memory......
Are they using cells that no one else has?
Here's another...
For over 20 years we’ve guaranteed that SR NiCd packs won’t form a memory and none ever has, so that’s not an issue.
I don't think a pack that would only cycle to 20% capacity would have a memory...it's just dead. One or more cells have failed. I guess you can say a pack that is dead has a memory. I would be interested to know if the packs you think have a memory have been used continuously or have been seldom used. My understanding is that to form a "memory" the charge has to be almost perfectly to the same point many times so that it permanently changes the chemistry of the cells, where a depression can be caused by non-use and is temporary...though I'm not sure about the last part. I need a ruling from Red.
I guess we are just calling it different things.
Bob
Bob Convery
       Post #: 14
Is there really NI CD memory? - 4/5/2003 9:53:57 PM
strato911
Status: offline
Hey Bob - I suggest in the future when you quote, include the FULL intent of the message.
The full quote from SR batteries is:
