SinCityJets
Joined: 11/13/2005 From: Henderson, NV, USA Status: offline
SS, You have it just the opposite. A 3 cell lipo drops from 12.6 to 10.5, almost IMMEDIATELY when running them hard. They also have a constant discharge rate, so the voltage is constantly dropping from 10.5 until they reach their cut-off point (9 volts or whatever you have the cut-off set at) A123's on the other hand, discharge almost flat. A 3 cell A123 (10.8 to start) will only drop to 10.2 for most of the duration of the discharge, until reaching cut-off. The only "negative" is that voltage is NOT a good indicator of how much energy is left in these cells. Because their discharge curve is so flat, you have to become "familiar" with these cells by flying them, and then charging them to gauge how many Mah you used. After doing this a few times, you will learn how many flights/minutes you can get out of a pack. Of course you could also use an in-flight data recorder that records amps, volts, power used during a flight. I guess you could use them on the ground or water too.
_____________________________
www.sincityjets.com Sin City Jets ''08 Jet Rally November 7-9 Alan & Patricia from Boomerang Jets are coming....are you?
