AFP won't start after new hard drive
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> AFP won't start after new hard drive Page: [1]
Login
AFP won't start after new hard drive - 11/30/2007 11:28:40 PM
CHM
Status: offline
I installed a new 200GB hard drive. Previous AFP install (with expansion pack and 168 update) worked perfectly for years (80GB drive). I installed the program, then the expansion, then the update as per the website. Windows XP and all apps are on a 30GB partition.
I get this error: Aerofly Pro main executionable has encountered a problem and needs to close. Then it goes bye bye. When I first launch I get the black screen and the blue and yellow logo as usual.
Any thoughts?
Thanks!
Click to see fullsize image.
Click for fullsize
< Message edited by CHM -- 12/1/2007 6:24:46 PM >
_____________________________
"I'd like one large Yak to go. Could you supersize that for me please?"
       Post #: 1
RE: AFP won't start after new hard drive - 12/3/2007 2:45:16 AM
rajul
Status: offline
CHM, could you post your tmlog file here? The tmlog file can be found in the AFP program directory. You can open the file using a text editor like notepad or word. Have you considered upgrading to AFPD for a low cost?
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
(in reply to CHM)
       Post #: 2
RE: AFP won't start after new hard drive - 12/3/2007 3:00:09 AM
CHM
Status: offline
Thanks for the response. I am actually considering Realflight G3.5....
Here is my TM text file. (I'm not exactly sure which file you are asking for)
tm: Library Version 4.0, Copyright (C) 1999-2003, IPACS
tm: http://www.ipacs.de
tmsystem: init random with 420429840
tmsystem: cpu type=(nlogical=1) (nphysical=1) (hyper-threading disabled)
tmsystem: cpu=1993 Mhz
tmsystem: memory=(physical=767MB, avail=508MB) (virtual=2047MB, avail=1856MB)
tmsystem: operating system=Microsoft Windows XP Version 5.1 Service Pack 2 (Build 2600) Service Pack: Service Pack 2 (Build 2600)
afdesign: init ok
tmgl: loading font v2 texture/serif10.tmf=(256x256) (32x255) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Version 1.6.8.0, Copyright © 1998-2004 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
directsound: register sound sound/beep.wav=ok
directsound: register sound sound/balloon.wav=ok
directsound: register sound sound/crash.wav=ok
directsound: register sound sound/splash.wav=ok
directsound: register sound sound/glider.wav=ok
directsound: register sound sound/glider2.wav=ok
directinput: init=ok
tmsystem: current monitor frequency=75
init window=(window=800x600) (screen=1024x768) (32bpp) (75Hz)
directsound: init=(speakerconfig=unknown) (certified) (cont.rate) (primary 16bit) (samplerates 5000,100000) (64 hwbuffers) (0 hwbytes)
init pixelformat=ok
gl: vendor=Microsoft Corporation, renderer=GDI Generic, version=1.1.0
gl: (viewport=16384x16384) (texturesize=1024) (stencil=8)
gl: extensions=GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
wgl: extensions=none
gl: extensions=(paletted texture)
wgl: extensions=
gl: software rendering
gl: reducing max texture size from 1024 to 512
tmsystem: fullscreen modes=(640x480-16-60) (640x480-16-70) (640x480-16-75) (640x480-16-85) (640x480-16-100) (720x480-16-60) (720x576-16-60) (800x600-16-60) (800x600-16-70) (800x600-16-75) (800x600-16-85) (800x600-16-100) (848x480-16-60) (848x480-16-70) (848x480-16-72) (848x480-16-75) (848x480-16-85) (848x480-16-100) (1024x768-16-60) (1024x768-16-70) (1024x768-16-75) (1024x768-16-85) (1152x864-16-60) (1152x864-16-70) (1152x864-16-75) (1152x864-16-85) (1280x720-16-60) (1280x720-16-70) (1280x720-16-75) (1280x768-16-60) (1280x768-16-70) (1280x768-16-75) (1280x960-16-60) (1280x960-16-70) (1280x960-16-75) (1280x1024-16-60) (1280x1024-16-70) (1280x1024-16-75) (1360x768-16-60) (1360x768-16-70) (1360x768-16-75) (1600x900-16-60) (1600x900-16-70) (1600x900-16-75) (1600x1024-16-60) (1600x1024-16-70) (1600x1024-16-75) (1600x1200-16-60) (1600x1200-16-70) (1600x1200-16-75) (640x480-32-85) (640x480-32-100) (720x480-32-60) (720x576-32-60) (800x600-32-85) (800x600-32-100) (848x480-32-60) (848x480-32-70) (848x480-32-72) (848x480-32-75) (848x480-32-85) (848x480-32-100) (1024x768-32-85) (1152x864-32-85) (960x720-16-80) (1152x900-16-76) (1152x921-16-66) (1152x921-16-76) (960x720-32-80) (1152x900-32-76) (1152x921-32-66) (1152x921-32-76)
directinput: searching joystick=none
< Message edited by CHM -- 12/3/2007 3:48:41 AM >
(in reply to rajul)
       Post #: 3
RE: AFP won't start after new hard drive - 12/3/2007 3:24:02 AM
rajul
Status: offline
Hi CHM, I only need the tmlog file. Could you post the full file, and don not truncate any part of the file. Thanks
Mike Marks
RCU Moderator
(in reply to CHM)
       Post #: 4
RE: AFP won't start after new hard drive - 12/3/2007 3:30:16 AM
CHM
Status: offline
Mike,
Which file is the tmlog file? I opened the tm text file in notepad and copied it and pasted it in my previous post. Here it is again (in full).
tmsystem: init random with 859445600
tmsystem: memory=(physical=767MB, avail=345MB) (virtual=2047MB, avail=1860MB)
afdesign: init ok
init pixelformat=ok
wgl: extensions=
(in reply to rajul)
       Post #: 5
RE: AFP won't start after new hard drive - 12/3/2007 3:41:17 AM
rajul
Status: offline
Hi CHM, for AFP you will need a open-GL 3D card from Nvidia or ATI with at least 32 MB. From your tmlog it looks like you're using the on-board video card. Which video card do you have and did you install it properly with the latest drivers?
Mike Marks
RCU Moderator
(in reply to CHM)
       Post #: 6
RE: AFP won't start after new hard drive - 12/3/2007 3:47:35 AM
CHM
Status: offline
Mike, (thanks for the help) it's the same video card that came with the machine and it's been working for years with AFP - an NVIDIA GeForce2 MX/MX400.
The only change is that I upgraded to the new drive and reinstalled all my software.
I could search for driver updates???
(in reply to rajul)
       Post #: 7
RE: AFP won't start after new hard drive - 12/3/2007 3:50:57 AM
rajul
Status: offline
Hi CHM, the card will work fine with AFP but it seems like the card is not installed. You may also want to use a backdated driver as the latest nvidia drivers are huge files.
Mike Marks
RCU Moderator
(in reply to CHM)
       Post #: 8
RE: AFP won't start after new hard drive - 12/3/2007 3:53:18 AM
CHM
Status: offline
I'll try that. Thanks! By installed I'm assuming you mean software-wise since it is physically where my monitor has been plugged in since 2002.
(in reply to rajul)
       Post #: 9
RE: AFP won't start after new hard drive - 12/3/2007 4:03:00 AM
rajul
Status: offline
Yes, and keep me updated
Mike Marks
RCU Moderator
(in reply to CHM)
       Post #: 10
RE: AFP won't start after new hard drive - 12/3/2007 4:23:10 AM
CHM
Status: offline
Thanks Mike! I got it. I downloaded and installed 61.77_win2kxp and it runs fine.
THANKS!
(in reply to rajul)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
