gearing on hellfire with lrp
Tower Hobbies
Logged in as Guest
  Printable Version
Traxxas Slayer NIB with Bonus Charger and Battery - RTR
Seller:  fgbasher
Details:   $400.00   |  12/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> gearing on hellfire with lrp
Page: [1]
Login
gearing on hellfire with lrp - 12/1/2007 6:12:09 PM
zsar1
Status: offline
hi .i tried to put an lrp 28 with pull start with a 16t clutch bell.but it would noy fit.i also had to use 2 of the purple engine mounting plate so that the engine would sit properly on the chasis.the bottom of the engine is too high.i dont want to grind the bottom because it might ruin the pull start.because on the engine sitting a little higher the 16t wont fit.i have now put the 12t back in.it now stays perfectly meshed without the engine moving.will thelow gearing harm the diffs with the torque of this new motor
_____________________________
zsar1
       Post #: 1
RE: gearing on hellfire with lrp - 12/2/2007 2:04:13 AM
stussman
Status: offline
The pull start sits a little lower than the crankcase which caused your problem. The bump start version would have dropped in. The hellfire diffs can be a problem so make sure you shim them. You should be ok then with loads of grunt on the bottom end. A 14t would probably be best if it fits.
(in reply to zsar1)
       Post #: 2
RE: gearing on hellfire with lrp - 12/6/2007 11:00:29 PM
Mr snuggles
Status: offline
where did you find 12t cb for the hellfire as hellfire rtr comes with 13t and i havent found smaller one on hpi site
(in reply to stussman)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU4
