Composite design factors
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Composite design factors
Page: [1] 2   next >   >>
Login
Composite design factors - 12/1/2007 6:46:31 PM
madfreestyler
Status: offline
Can anyone recommend a good site for calculating the stregnth of composite structures.
I know it will depend on thickness, resin, cloth etc etc.
The question stems from some ideas that i have to make a few composite planes and hopefully if i can get it right maybe produce a few. What i am trying to figure out is if i need an internal structure to add to the stregnth of the aircraft or if the right resin and thickness is used maybe not required i need to get my head round the trade offs?
Same applies to the wings, if you are going composite like the comp arf stuff do you still need formers in the wings? More to the point how do you mould a wing and get the leading and trailing edges joined right.
I know i had a eurosport a while back and im sure that only had a former at the root. The fus was pretty much the same, there were formers for the turbine and i think there was 1 towards the back where the under faring was fixed.
Any pointers much appreciated.
< Message edited by madfreestyler -- 12/1/2007 6:47:38 PM >
_____________________________
I Just Wanna Fly
       Post #: 1
RE: Composite design factors - 12/1/2007 7:00:23 PM
ByLoudDesign
Status: offline
Although this site is for tubes the properties are the same for sheet or layup!
http://www.carbonfibertubeshop.com/tube%20properties.html
Projects on the board: Stinson SR-9, Orion P-3, Dornier DO-24, Howard 500, Pilatus PC-9 Future Projects: Curtiss F11-C2, Osprey VC-22, Canadair CL-415, Connie CL-121, Stinson Model A Gruman TBM,
bylouddesign.com "Scale without compromise"
(in reply to madfreestyler)
       Post #: 2
RE: Composite design factors - 12/1/2007 10:51:22 PM
seanreit
Status: offline
It all depends on design. This jet has NO formers! The "formers" were built into the design to be composite. See where the hatches are, there is structural support across the fuse from the original glass lay up. This jet is 3 layers of 6 ounce, doubled up around the intake area for about 3 inches.
Mileage may vary, but this one is a good example of what can be achieved to save some weight and extra work.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to ByLoudDesign)
       Post #: 3
RE: Composite design factors - 12/1/2007 11:02:20 PM
madfreestyler
Status: offline
Awesome!!!!!!!!! Dont suppose you would care to share your mould making and moulding technique?
What do you use to design your models?
I Just Wanna Fly
(in reply to seanreit)
       Post #: 4
RE: Composite design factors - 12/1/2007 11:52:21 PM
seanreit
Status: offline
There isn't really a secret. As incredible as it may seem, I have read every single thread in this forum related to composites and mold making. I was out of town on business a few years ago, and spent literally about 40 hours in the evenings reading and absorbing information. I've invested thousands in technology, materials, and equipment to make my dreams a reality. It's a lot of work, but can be very rewarding.
Good luck, and when you get going, if you run into questions, post them, there are many here with more experience than me that can help.
       Post #: 5
RE: Composite design factors - 12/3/2007 3:09:14 PM
Magne
Status: offline
It is also worth noting that models such as the Comp-ARF (and others) that don't have formers, are all sandwich structures, i.e. fibres (glass/carbon/kevlar) laid up on each side of a light weight core material. The core material could be balsa wood, honeycomb or foam. The core material separates the two skins, and make a stiff, lightweight structure. A single skinned structure would need to be many times heavier to achieve the same stiffness.
Magne
       Post #: 6
RE: Composite design factors - 12/4/2007 5:09:02 AM
SCALECRAFT
Status: offline
Fuses have been done for years,lot of info. The wings/stabs are the trick..
I would also like to make a point about stiffness in the glass "skin"construction. For the last 16 years my buddy and I have been making/flying all composite warbirds that have a few layers of glass along with minor wood/composite framework in the fuse and hollow glass wings.
The glass skin in wings mainly, without a sandwich core material may not be stiff to the touch at some points as a core type wing, but the glass/frame wing is just as light and has never failed us in flight. Plus the glass skin coreless wings don't dent as do the sandwich construction type, like the old fiberclassics P-51 for example. Not a very durable surface, the foam core would dent and not bounce back.
ALso glass coreless wings are cheaper and easier to do. No vacuum bagging needed. Well this is what has worked well for us for many years.
Once you start to work with glass , shapes, and angles, you'll see how it can all work together.
Jet remember, its not going to be crash proof.
Steve
(in reply to Magne)
       Post #: 7
RE: Composite design factors - 12/4/2007 8:43:01 AM
Magne
Status: offline
Steve.
I am very interested in what you are saying.
Could you please indicate what lay-up schedule has worked for you.
What material thicknesses are required for adequate handling strength, and what is you recommended distance between the ribs/formers.
Magne
(in reply to SCALECRAFT)
       Post #: 8
RE: Composite design factors - 12/4/2007 11:46:33 AM
Ed Smith
Status: offline
I am always experimenting. As seanreit stated there are no secrets. Many years ago I incorporated Carbon tow in my fuselage layups. The added stiffnes was quite amazing. I wind the tow into a string and sandwich it between the layers of cloth. The pictures illustrate this, The tow is sandwiched between two layers of six ounce cloth. The extra strips above the front of the wing saddle stiffen the fuselage above the landing gear. The weight of the added carbon was less than one ounce. No additional resin was needed the carbon just suck up what was being used for the layup. I use only epoxy resin. The fuselage in the picture is 48" long. Apart from the firewall and the servo tray there are no other formers in the fuselage.
The strips in the cheek cowls did not do what I wanted. I should have laid them across the cowl not along them. Next time. The wheel pant strips of carbon are self explanatory.
Ed S
Click for fullsize
Click for fullsize
(in reply to Magne)
       Post #: 9
RE: Composite design factors - 12/4/2007 3:04:56 PM
seanreit
Status: offline
Ed, on my fuse, on the jets one of the factors is that we carry a lot of weight in the nose that has to be supported (we figure supported around the intake area). I have never used Tow, and we were thinking just lay in some carbon fiber triangle cut from the intake area up the sides towards the nose.
Does tow have much strength say over a two foot run? I was thinking surface area of carbon fiber, but if this stuff makes a beam over length, might be just the trick??
Note: fuse is three layers of really loose weave 6 ounce. Lots of curves in this baby and the loose makes the turns quite well.
< Message edited by seanreit -- 12/4/2007 3:05:48 PM >
(in reply to Ed Smith)
       Post #: 10
RE: Composite design factors - 12/4/2007 3:36:42 PM
Ed Smith
Status: offline
Sean,
The lengthways strip in that fuselage is 20" long. It is 1" tow twisted into a string. Just laid in flat the tow does not add much stiffness. Twisted into a string the difference is quit amazing. Two or three strands laid side by side would definitely give you a "Beam" like structure add a couple of verticals and the fuselage would be very stiff.
I mold my own Pyon Racing fuselages. I use the same principle with those. For me Carbon Tow strategically placed is the lightest easiest way to stiffen a fuselage.
Ed S
       Post #: 11
RE: Composite design factors - 12/4/2007 4:19:01 PM
tony-howard
Status: offline
One of the best books on composite structures the I've seen is:
Composite Basics by Andrew C Marshall
Published by Marshall Consulting
720 Appaloosa Drive
Walnut Creek CA 94596
My copy was purchased in 1994 and finding a copy may not be easy now.
It is intended for full scale homebuilt design, but it contains a wealth of information for any composite structure designer. It's well organized, easy to understand and has one of the better sections on cloth weaves. Edition 4 includes carbon fiber.
HTH
Tony
pacific-scaled-aircraft.com
       Post #: 12
RE: Composite design factors - 12/4/2007 6:25:18 PM
HO-229
Status: offline
Ed,
I like what you have done with the "tow" material, I find it to be a very innovative way of incorporation stiffeners/ribs within the fuselage structure without the fuss of making stand alone rib structures & bonding them to the inner skin structure
Thanks for the tip
Regards
Dave
       Post #: 13
RE: Composite design factors - 12/5/2007 4:25:40 AM
Spike
Status: offline
quote:
ORIGINAL: tony-howard
720 Appaloosa Drive
HTH
I found a copy here: http://www.actechbooks.com/composite_basics.htm
(in reply to tony-howard)
       Post #: 14
RE: Composite design factors - 12/5/2007 6:36:07 AM
tony-howard
Status: offline
