RE: Extreme Flight 110" 100cc Yak 54 Build!
Tower Hobbies
Logged in as Guest
Users viewing this topic: kochj
  Printable Version
Rich Model 35% Extra 260 - Add engine & rx - ARF
Seller:  ScaleFreak
Details:   $1,200.00   |  12/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight 110" 100cc Yak 54 Build!
Page: <<   < prev  10 11 [12] 13 14 15 16 17 18 19   next >   >>
Login
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 2/10/2008 11:27:34 PM
Flyin Hawaiian
Status: offline
Clark,
The Stand-offs for the DA 100 are 1".
_____________________________
Rennie "Fly Low & Slow & In Control!"
Team Extreme of extremeflightrc.com / B & E Graphix
(in reply to Rush7)
       Post #: 276
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 2/11/2008 1:03:38 AM
Rush7
Status: offline
Thanks for the info Rennie. I will order the 1" standoffs. I am going with the Dubro light weight 5" wheels and PSP axles. I was going to use the Kavans but I have heard of a lot of people having issues with the big Kavans.
Clarke
< Message edited by Rush7 -- 2/11/2008 1:10:36 AM >
http://www.crccflyers.org
Huckin'' til it hurts
(in reply to Flyin Hawaiian)
       Post #: 277
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 2/24/2008 6:51:12 PM
kochj
Status: online
For those using other brands of engines, this doesn't apply...
The DA 100cc twin will be updated and loose weight
That may help even more .....
released in April???????
THats all...
Justin
< Message edited by kochj -- 2/25/2008 4:00:01 PM >
Winning isn''''t everything, it''''s all there is.
(in reply to Rush7)
       Post #: 278
RE: Extreme Flight 110" 100cc Yak 54 B... - 2/25/2008 4:07:46 AM
Rush7
Status: offline
I am hoping with the ES pipes on my DA-100 that will fo the trick. I cant see the DA-100 on stock mufflers having to much trouble as long as it is kept light.
There is a guy at the field that I fly with that has Carden Edge 540 getting close to the 30lb mark with a DA on stockk mufflers and it does pretty well.
(in reply to kochj)
       Post #: 279
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 2/25/2008 1:25:51 PM
pfoot748
Status: offline
That's interesting. I haven't purchased a motor for mine yet. That makes the 100 sound even better.
< Message edited by pfoot748 -- 2/25/2008 1:28:23 PM >
(in reply to kochj)
       Post #: 280
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 2/25/2008 3:24:42 PM
dbcaster
Status: offline
The new DA 100 is actually 6 oz. lighter not 16 with a claimed 150 to 200 rpm increase. It does sound good though.
(in reply to pfoot748)
       Post #: 281
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 2/25/2008 4:02:38 PM
kochj
Status: online
Iwould think that it will not make a HUGE dif. between the one out now....
I am sure htat one could update there curent engine if they really desired too...
I for one have a Relitivly new DA100 with about 7-fights on it.... I am not going ot waste my money on new upgrades unless it will get rid of th midrange
Grubble....
I am ging to use Cf pipes or Grieves....
(in reply to dbcaster)
       Post #: 282
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 2/25/2008 6:04:34 PM
dbcaster
Status: offline
It looks like the new one does not have the integrated aluminium intake. It now has the red nylon, or what ever plastic type material between the case and carb. To upgrade you would need a new case or have the old one re-machined. I agree it would not be worth the cost of the upgrade for 6 ounces of weight savings. The new intake may git rid of the mid range grubble but I guess that remains to be seen. Not that it is that much of an issue but your tuned pipes may take care of that as well. The pipes will also take care of any power concerns. I think the main thing it will do is give those of us that don't see a big need to have the new engine a good deal on a used old style DA 100
(in reply to kochj)
       Post #: 283
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 2/25/2008 6:11:20 PM
pfoot748
Status: offline
Yeah, 6 oz isn't as impressive as 16 oz but it does all add up. I thought maybe they re-designed the whole crankcase but apparently they are just lightening the existing one.
       Post #: 284
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 2/25/2008 8:35:30 PM
yarom
Status: offline
If properly adjusted, your DA-100 will get rid of the mid-range burble after about 2gal and become smooth as a 4 cycle after 4gal. When you switch to 1:80 Amsoil mix, you might even pick up some rpm.
quote:
ORIGINAL: kochj
Grubble....
(in reply to kochj)
       Post #: 285
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 2/25/2008 8:58:07 PM
Flyin Hawaiian
Status: offline
My DA 100 on ES pipes has no midrange burble, nor did any of my other two 100cc. Yarom is nialed it down, During break-in, because of the rich settings, the DA 100, like any other gas motor, will get a mid-range burble, which is normal. After break-in (as recommended by DA) I switched to Amsoil Sabre mixed with mid-grade fuel and 80:1 Amsoil. With the ES composite pipes, it really woke up the DA 100. On the ground I am turning a Vess 28B prop at 7500-7700 rpms. Can you say throttle management. The only problem I have with the ES pipes is, I had to dial up some throttle curve. The power came on strong at 3/4 throttle. Otherwise hovering was a real chore.
kochj, Seven flights is not enough flights. But enough to be able to lean out the needles a bit. The DA midrange burble can be tuned out with both low and high needles. Jus keep flying, after three-four gallons switch to Amsoil, 80:1, mixed with midgrade, do a little carb tuning, and you would swear it was a different motor. In addition, Depending on your flying style, and if you have tuned pipes or stock muffs, try a Vess 27B or 28B props., Just in the Vess prop chnage along, you would swear that you bolted on a turbo!!!!
As far as a stock DA on the 110" Yak, It should do fine. Just keep it very light!! I even think that a DA85 on tuned pipe on high test fuel mix, should give this big bird ample power!
< Message edited by Flyin Hawaiian -- 2/25/2008 9:00:16 PM >
(in reply to yarom)
       Post #: 286
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 2/25/2008 9:34:32 PM
kochj
Status: online
FFH,
No question that any engine when placed with Tuned CF pipes is a monster!! No doubt....
Thank you for the advice about the props..... Is this on stock mufflers? or Tuned pipe?
I have had some horrible luck with engines and airframes this last year (2007) I would have thought that there was a hex on me!!!!
Hopefully 2008 means good luck....
My DA100 quit on me after it's 4-flight. I think it was too lean on idle and rich on High (on ashless lawnboy break in) right when I was doing a very slow flyby tring to get it ready to land and find out the planes stall attributes....
End result? Snaped fuse in half!!!!.. and damaged R-wing.....
I should have scraped the plane, but rebuilt it.... Had dead stick after dead stick.... (It was due to having the spark plug cap laying on the hot stack muffler///) This forced me to land hard, because I didn't want the plane to float by... and wouldn't you know?
Due to the R-wing repair it was way way too heavy, and the wing did not sit up next to the fuse so the wing was able to do this, very bad leverage thing on the CF maintube....
It caused cracking and weakining that I could not see.....
Got a new wing , took it up, and wouldn't you know.... The wingtube broke, and the wing departed from the plane way way up in the air at the top of the loop!!!!!!
Anyway..... I have a new plane and new cf wing tube.... and the DA engine was checked over and a new hub was placed on it....
My point is that the engine didn't seam to perform well but this was due to over weighted, repaired airframe and still breaking in engine.....
I will see how it goes the second time!!!!!!
       Post #: 287
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 3/8/2008 1:45:39 AM
rcairmike
Status: offline
the thread hasnt ad a post in awhile.nothing like a shipment of 110 yaks coming in to get thread going again.that is happening soon i hope.any word how long the waiting list is.im selling my 88 yak this weekend in hopes of starting the new 110 soon.heres a pic of my ef yak foam plane for winter months.just to keep thoughts of how great the real yak flies.
< Message edited by rcairmike -- 3/8/2008 1:46:40 AM >
(in reply to kochj)
       Post #: 288
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 3/8/2008 2:57:23 AM
xtraflyr
Status: offline
quote:
ORIGINAL: rcairmike
Go onto the EF website. I believe Chris said the end of March. The 110" is goin to be outta my pocket range for awhile.
Cya,
Frank
www.njjf.org
www.njjf.freeforums.org
(in reply to rcairmike)
       Post #: 289
RE: Extreme Flight 110" 100cc Yak 54 Bu... - 3/9/2008 3:31:58 PM
