RE: Extreme Flight 110" 100cc Yak 54 Build!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight 110" 100cc Yak 54 Build!
Page: <<   < prev  14 15 [16] 17 18 19 20 21 22 23   next >   >>
Login
RE: Extreme Flight 110" 100cc Yak 5... - 4/30/2008 12:57:17 AM
Josey Wales
Status: offline
At this point it looks like by the time they get shipped out its more likely that we wont see them until June-
Looks like I may have to look at plan B
_____________________________
Joe
I''''''''m a magician, every day I turn into my driveway.
(in reply to Rush7)
       Post #: 376
RE: Extreme Flight 110" 100cc Yak ... - 5/1/2008 12:08:40 AM
rcairmike
Status: offline
you know you will only kick yourself for going to plan b and not waiting for the ef
(in reply to Josey Wales)
       Post #: 377
RE: Extreme Flight 110" 100cc Yak ... - 5/1/2008 12:37:48 AM
Josey Wales
Status: offline
quote:
ORIGINAL: rcairmike
No Plan B is to drive to EF's headquarters and camp out on the front lawn until I get my Yak!
Joe
(in reply to rcairmike)
       Post #: 378
RE: Extreme Flight 110" 100cc Yak ... - 5/1/2008 2:45:47 AM
Scoubidou
Status: offline
It's amazing to see so much loyalty to one supplier when there are so much others good products available and in stock. Personnelly , I would not loose a season waiting for a plane but it's me and i admire those who do that.
Daniel
Seneca Engineering
http://www.seneca.ca/
       Post #: 379
RE: Extreme Flight 110" 100cc Yak ... - 5/1/2008 2:46:47 AM
Absolut Yak
Status: offline
[/quote]
[/quote]
Do that and Melissa will send the beagles out to pee on your tires.
Stand Back! I'm Fixin' to Yak!
       Post #: 380
RE: Extreme Flight 110" 100cc Yak ... - 5/1/2008 2:55:36 AM
Jake Ruddy
Status: offline
quote:
ORIGINAL: Scoubidou
Daniel
The problem is there is nothing out there that compares to this plane in size, wing area, and weight. That is why the 50cc versions sell out almost before they even arrive.
(in reply to Scoubidou)
       Post #: 381
RE: Extreme Flight 110" 100cc Yak ... - 5/1/2008 3:07:46 AM
Josey Wales
Status: offline
quote:
ORIGINAL: Scoubidou
Daniel
I can understand that-It does suck that there have been so many delays..I have had about 6 EF planes and have flown some other brands but they just don't stack up IMO...so I will wait
quote:
ORIGINAL: Absolut Yak
Ill wear my waders!!!
< Message edited by Josey Wales -- 5/1/2008 3:08:45 AM >
Joe
       Post #: 382
RE: Extreme Flight 110" 100cc Yak ... - 5/1/2008 4:16:23 AM
Rush7
Status: offline
I just hope that when they call I can get off from work and head that way. I am going to have to take the trailer to get them becasue I will be picking up two of them. If they get here on time I hope to have mine in the air by the end of May.
http://www.crccflyers.org
Huckin' til it hurts
       Post #: 383
RE: Extreme Flight 110" 100cc Yak ... - 5/1/2008 4:37:09 AM
Purple Bird
Status: offline
Are all of the first shipment already spoken for? I was curious if he might bring some to sell at "3D Unleashed" in High Point NC on June 28th.
(in reply to Rush7)
       Post #: 384
RE: Extreme Flight 110" 100cc Yak ... - 5/1/2008 5:22:10 AM
Flyin Hawaiian
Status: offline
quote:
ORIGINAL: Josey Wales
quote:
ORIGINAL: Scoubidou
Daniel
Rennie "Fly Low & Slow & In Control!"
Team Extreme of extremeflightrc.com / B & E Graphix
       Post #: 385
RE: Extreme Flight 110" 100cc Yak ... - 5/1/2008 11:39:13 PM
diamondave
Status: offline
my birthday is monday the 5th.......hint, hint, chris
(in reply to Flyin Hawaiian)
       Post #: 386
RE: Extreme Flight 110" 100cc Yak ... - 5/2/2008 4:21:23 AM
rcairmike
Status: offline
maybe someone could help clarify this for me.in my comp arf yak im using a swb cable tray to gang servos for rudder.i was told that when using the method outlined for the ef 110 yak on the slave servo for rudder, you dont need to connect both link arms.one arm is just fine.
(in reply to diamondave)
       Post #: 387
RE: Extreme Flight 110" 100cc Yak ... - 5/2/2008 5:46:48 AM
bgold
Status: offline
I think that one servo connects to the next servo and that servo connects to the arm that pull-pulls the rudder. The system will work if one servo fails or only one is hooked up but you won't get the effect of both servos that way, it's just a setup that allows it to work if only one servo is operational.
       Post #: 388
RE: Extreme Flight 110" 100cc Yak ... - 5/2/2008 3:17:21 PM
rcairmike
Status: offline
i fully understand how the set up works.let me explain my question better.on the slave servo on the ganged rudder servos.is it needed to run 2 links off the servo arm of the slave servo to the main servo with the 4 inch of set witch the pull/pull cables are attached to.you would think that 2 links of the servo arm to the othe servo arm isnt needed.just one link
(in reply to bgold)
       Post #: 389
RE: Extreme Flight 110" 100cc Yak ... - 5/2/2008 7:15:22 PM
rcairmike
Status: offline
could someone who has this built tell me whats the largest size wheel that fits under the wheel paints.
       Post #: 390
RE: Extreme F
