valle
quote:
ORIGINAL: drewbags quote:
ORIGINAL: valle I was about to install horns to the ailerons, when I realized that the thickness of the aileron is different at the horns. This means that the horn's length in relation to the hinges is different, if the provided horns are used. Which then means that the servos will be prising against each other, if they are used in same channel. The difference of the length is few millimeters. The two holes in the horns do not solve the problem, because their distance from each other is different that the length difference, in direction of the push rod. In addition to that, only one hole is at the hinge line. I was planning to use one channel for two servos in Powerbox, which does not have adjustment feature for servos. Did you manage to install and make the servos and ailerons work normally without using servo matchboxes, equalizers or programmer? R, Valle I used a matchbox on each wing and it seems to be fine. Thanks for answers drewbags. I got email from FS-RC saying that I might get the manual next week. I'll put the matchbox into consideration. R, Valle
