JoeAirPort
WI, USA Status: online
quote:
ORIGINAL: Josey Wales Thats not what I mean-What I want is equal throw in both directions and at the same time have the servo arm move the same distance each way from center. If I just adjust the linkage to hold the control surface at the center, then use the programmer to set the max throw each way, the geometry is way off. Joe, I know exactly what you mean. Another guy from Finland, Norway or somewhere posted this same issue a few weeks ago. If the horn height is not adjustable then you can't match the geometry a la DOD method. I think you'll have to compensate electronically which will cause some mismatch in speeds. The aileron must have enough flex to be able to absorb it IMO. I think that's what people must be doing with this fixed horn height. The only other thing you could do is drill new holes in one of them if you knew where the hole had to be. I think the inboard one would have to be lower.
< Message edited by JoeAirPort -- 6/9/2008 12:08:05 AM >
_____________________________
Joe AP
