RE: Extreme Flight 110" 100cc Yak 54 Build!
Tower Hobbies
Logged in as Guest
Users viewing this topic: kochj
  Printable Version
Wow! H9 33% Cap 232 New in Box! No Haggle Price!
Seller:  Dustflyer
Details:   $550.00   |  12/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight 110" 100cc Yak 54 Build!
Page: <<   < prev  29 30 31 32 33 [34] 35 36 37 38   next >   >>
Login
RE: Extreme Flight 110" 100cc Yak... - 10/14/2008 1:30:57 PM
torqmeister
Status: offline
Looking good, Charles. Git-R-Done. Welcome back to Texas.
_____________________________
AMA 8051
(in reply to cjcyclesrc)
       Post #: 826
RE: Extreme Flight 110" 100cc Yak... - 10/15/2008 9:09:54 PM
bblizzard
Status: offline
hi,
need some help, has anyone tried a bme 105, mine (has the 110 case) with stock muff's fly the 110 yak ok? just not sure because of it's larger than average size. my motor turns about 6400 with a vess 27a, flew my bvm edge just fine and wieghs about 2 lbs less than the da-100. i saw where some guys used a kroma 100 but not sure how that compares to the bme 105.
any thought's would be a great help! trying to decide between the ef 110 yak and the new qq 101 yak
thanks, brad
< Message edited by bblizzard -- 10/15/2008 9:18:59 PM >
(in reply to torqmeister)
       Post #: 827
RE: Extreme Flight 110" 100cc Ya... - 10/16/2008 2:34:24 AM
Rush7
Status: offline
Brad I dont think that your BME would have any trouble flying the 110" Yak. Swinging a Vess 27A at 6400 sounds like it will work fine. I have no expereince with the QQ planes but I dont think that you will be disappointed one bit with the EF 110" Yak. I love this plane and I think that it flies as close to a 40 center as you can get.
http://www.crccflyers.org
Huckin'' til it hurts
(in reply to bblizzard)
       Post #: 828
RE: Extreme Flight 110" 100cc Yak... - 10/16/2008 4:49:27 AM
torqmeister
Status: offline
quote:
ORIGINAL: bblizzard
hi,
thanks, brad
The 110" Yak is a 35% that presents itself like a 40%. I have 32 flights on mine & I absolutely love it. my flyimg buddy has a 118" Yak, and he says mine flies just like his. I highly recommend the 110" Yak. If your BME 105 turns a Vess 27A @ 6400 rpm, you will have a real performer on your hands. This plane is bigger than a 40% Edge 540. Mine has 8 gal. through it on a Bolly 26x10 break-in prop @ 6500 rpm. and it has unlimited vertical,, & great pull out of a hover.
AMA 8051
       Post #: 829
RE: Extreme Flight 110" 100cc Yak... - 10/16/2008 5:02:11 AM
torqmeister
Status: offline
I'll probably get flamed for this, but your BME has very similar power to a Da100, set up similarly with stock exhaust. Plus being lighter gives it definite advantages in power/weight ratios. My Kroma is supposedly, 2 - 4 oz, kighter than a DA 100, has the batteries behind the rudder servo. There is plenty of room between the rudder servo & the tank for th batts, and also around the tank, or infront of the tank. Lota of possibilites. You goota have a 110" Yak.
AMA 8051
       Post #: 830
RE: Extreme Flight 110" 100cc Yak... - 10/16/2008 5:03:53 AM
torqmeister
Status: offline
AMA 8051
       Post #: 831
RE: Extreme Flight 110" 100cc Yak... - 10/16/2008 10:55:23 AM
Richard D Bahmann aka/Wrongway
Status: offline
quote:
ORIGINAL: torqmeister
How do you like that Kroma? How is the midrange and the performance?
Thanks!
To go where no man has gone before...without government permission. In 1938 Wrong Way Corrigan becomes an American Hero.
       Post #: 832
RE: Extreme Flight 110" 100cc Yak... - 10/16/2008 1:44:05 PM
torqmeister
Status: offline
I really like my Kroma 100. The mid-range is very smooth, with nice transition. Also, no matter what attitude the airplane is in, or what manuever I'm doing, there is no "burble" that I can detect.
Engines with double rings tend to break in a little slower. Mine is really coming on with the last 2 gal of fuel. I have 8 gal through it so far. There have been at least 5 tachs used on this engine, a Fromeco TNC & one unknown brand tached it at 6900 rpm, and three Hobbico tachs all have it right around 6500 rpm. I didn't want to be accused of exaggering these numbers, so I reported the 6500 rpm number.
I fly about an 70/30 mix of IMAC/3D. The performance has been excellent. I would rank it among the real quality engines available out there. I would recommend it to anyone.
After a couple more gal, I plan to move to a 27/10 prop.
AMA 8051
       Post #: 833
RE: Extreme Flight 110" 100cc Ya... - 10/16/2008 2:34:13 PM
Status: offline
Thanks!
       Post #: 834
RE: Extreme Flight 110" 100cc Yak... - 10/16/2008 5:14:09 PM
bblizzard
Status: offline
hi,
thanks, torqmeister for the info just wasn't sure if the bme 105 would handle the (bulk) of the ef yak. but since it's nearly 2lbs lighter than the da 100 i hope it's a wash lol! how muck does your's wiegh with the kroma 100?
       Post #: 835
RE: Extreme Flight 110" 100cc Yak... - 10/16/2008 8:14:30 PM
torqmeister
Status: offline
quote:
ORIGINAL: bblizzard
hi,
26 1/2 lbs.
Also, the 110" Yak tends to be a bit nose heavy, so you won't have any problem balancing it with the lighter engine.
The rolling manuevers on this plane are absolutely beautiful. It rolls perfectly axial, with no need for any differential. Since I'm here, I might as well add that the snaps are clean & precise.
AMA 8051
       Post #: 836
RE: Extreme Flight 110" 100cc Yak... - 10/16/2008 8:28:02 PM
bblizzard
Status: offline
so,
your palne is totally unlimited? if your 26 1/2 lbs i sould be 25 1/2 i think. how does it pull out of a hover walk ot run?
brad
       Post #: 837
RE: Extreme Flight 110" 100cc Yak... - 10/18/2008 4:43:07 AM
Rush7
Status: offline
quote:
ORIGINAL: bblizzard
so,
brad
Brad here is a video of mine. DA 100 on pipes pushing the porky side of 29lbs. At your weight you should rock out of a hover. Mine does pretty good but you can be the judge of it.
http://www.youtube.com/watch?v=a4UFKY7gh8g
< Message edited by Rush7 -- 10/18/2008 4:48:54 AM >
       Post #: 838
RE: Extreme Flight 110" 100cc Yak... - 10/19/2008 2:27:31 AM
kochj
Status: online
I just saw these..... little overkill, but man, do they just ooozzzz cheder!!!
Only issue is that you have to have a reciever that states it will take the full, 7.4 volts...!!
Click to see fullsize image.
Click for fullsize
Click for fullsize
