Flyin Hawaiian -> RE: Extreme Flight 110" 100cc Yak 54 Build! (12/17/2007 1:20:08 AM)
Josey you are correct on the rudder servo arms. Okay guys, made some real progress, even though it did take a little longer, but the extra effort was worth it. Now that my 50mm drop headers came in I can lay-out the tuned pipes, open up the cannister bays, and make the tuned pipe mount. I made the cannister bays so that the pipes have to slide in through the front of the tuned pipe tunnel. The EF 110" Yak pipe tunnel is long and did not have to use the whole length, so I blocked off the unused part with a piece of balsa. I know that these carbon fiber pipes do not dissapate heat very well, so like in my 88' Yak, So I stripped off the covering carefully and some vent holes out of balsa wood. Sanded the whole thing smooth and recovered it. It really dresses up the bottom, and is keeps plenty of air moving through.
