RE: Extreme Flight 110" 100cc Yak 54 Build!
Tower Hobbies
Logged in as Guest
Users viewing this topic: badedge540
  Printable Version
Top Flite GS Stab Relocation Kit - Kit
Seller:  tony-howard
Details:   $12.50   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight 110" 100cc Yak 54 Build!
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/17/2007 1:20:08 AM
Flyin Hawaiian
Status: offline
Josey you are correct on the rudder servo arms.
Okay guys, made some real progress, even though it did take a little longer, but the extra effort was worth it. Now that my 50mm drop headers came in I can lay-out the tuned pipes, open up the cannister bays, and make the tuned pipe mount. I made the cannister bays so that the pipes have to slide in through the front of the tuned pipe tunnel. The EF 110" Yak pipe tunnel is long and did not have to use the whole length, so I blocked off the unused part with a piece of balsa.
I know that these carbon fiber pipes do not dissapate heat very well, so like in my 88' Yak, So I stripped off the covering carefully and some vent holes out of balsa wood. Sanded the whole thing smooth and recovered it. It really dresses up the bottom, and is keeps plenty of air moving through.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Flyin Hawaiian -- 12/17/2007 1:24:54 AM >
_____________________________
Rennie "Fly Low & Slow & In Control!"
Team Extreme of extremeflightrc.com / B & E Graphix
(in reply to Josey Wales)
       Post #: 76
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/17/2007 1:33:42 AM
Jake Ruddy
Status: offline
Looks pretty good if you ask me!
(in reply to Flyin Hawaiian)
       Post #: 77
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/17/2007 1:40:14 AM
Flyin Hawaiian
Status: offline
Next I made the tune pipe mount. I designed it so that it comes apart, so that the pipe can easily slide in, and when in place it hold the pipe securly. I used black smoke oil line to insulate up against the CF pipes. I have used this in the past and works great!. Once pipe mount was glued in, cannister bays got the hi-temp BBQ grill back spray paint treatment, and the engine box got a shot of clear poly urathane. I think that the engine box and pipe tunnel already was fuel proofed, but I just wanted to be sure. After that I mounted the carbon fiber landing gear, which is included! LG installation was straight forward. The DA100 is mounted for good and the pipes look good installed.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Flyin Hawaiian -- 12/17/2007 2:09:00 AM >
       Post #: 78
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/17/2007 1:47:49 AM
Flyin Hawaiian
Status: offline
I think will have to redo the throttle linkage so that it has more clearance from the header. I probably will have to change it to metal rod so that I can give it acouple of bends. Also I am not real comfortable with the throttle servo close to all that heat. I am using a Hitec HD 6975HB digital servo. I would like to know what you guys think. Will this servo be alright there or should I relocate the servo?
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Flyin Hawaiian -- 12/17/2007 1:50:02 AM >
       Post #: 79
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/17/2007 2:57:59 AM
xtraflyr
Status: offline
quote:
ORIGINAL: Flyin Hawaiian
Hey Rennie,It's loooking gooood!! I would think that if Chris had it designed like that it would be fine.. Is that CF rod your using for your pushrod? Ive heard that CF will give you interferance,but if your using 2.4 Ill just shut up!!HAHAHA!! . I sure would like that CF gear for my 88"Yak....Looks purty it does..
Cya..
Frank
www.njjf.org
www.njjf.freeforums.org
       Post #: 80
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/17/2007 4:11:21 AM
martinarcher
Status: online
I've never run a servo that close to heat so I can't really say. You could mount it inside the motor box and cut a slit for the arm to poke through if you are worried about it. Heck use the current mount hole, just mount it inside the box. That would keep the servo case safe from any oil too.
Example...
Protected Servo
Those pipes look totally trick! I like them black on black - it hides them really well. People will be trying to find you exhaust while your hovering and have trouble!
Good to see that carb covered up while sanding!
Looking good so far - keep it up!
< Message edited by martinarcher -- 12/17/2007 4:12:00 AM >
(in reply to xtraflyr)
       Post #: 81
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/17/2007 1:13:10 PM
Flyin Hawaiian
Status: offline
I think I will relocate the Servo to the inside of the Engine Box, and closer to the front. Like MartinArcher has suggestedl, I will lay the servo on its side and let the long metal servo arm poke thru the bottom of the box, just for piece of mind that the servo will not have a 'Melt Down' next to the headers. I will have to make a removable tray, because I will be glueing the top of the motor box down, even though Chris H. says it can be screwed down, I believe it will be alot stronger if I glued it down.
< Message edited by Flyin Hawaiian -- 12/17/2007 1:14:18 PM >
(in reply to martinarcher)
       Post #: 82
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/17/2007 5:57:51 PM
Scoubidou
Status: offline
Hi Flyin Hawaiian
Does the Yak come with CF tail wheel bracket?
Seneca Engineering
http://www.seneca.ca/
       Post #: 83
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/17/2007 6:05:26 PM
dancer 3d
Status: offline
Hey Rennie, wonder if you could do me a favour? I'm going to be using Zimerman cans in my yak and need some dimensions for the headers. Could you be kind enough to take a few measurements for me please? The cans are 60mm dia, so i would like to know if they will fit under the undercart mount. I also see you have your headers offset slightly towards the center of the pipe tunnel, do you have a dimension for that? Would be much appreciated if you could do this for me please
Thanks, Nathan.
www.freestyle-rc.co.uk / www.extremeflightrc.com
       Post #: 84
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/17/2007 10:51:49 PM
Flyin Hawaiian
Status: offline
Scoubidou, SKOOOOOOOOBY-DOOOOOOO! I love that cartoon! Anyway the tail wheel is just like the 88" except bigger. In fact other than the twin cylinder engine two exhaust pipe, and two servos on wings and rudder, this 110" Yak goes together just like the 88".........Its just BIGGER!
Nathan, If you use tune pipe rear exit you will have plenty of room. If you are using reverse exit cans, the tunnel above the landing plate will be a little tight, but I think it will fit. The ES Composite pipes are approx. 50 mm in diameter and it has plenty of room.
(in reply to dancer 3d)
       Post #: 85
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/18/2007 3:15:13 AM
Josey Wales
Status: offline
Any idea of price yet ?
Joe
I''''''''m a magician, every day I turn into my driveway.
       Post #: 86
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/18/2007 4:52:05 AM
Flyin Hawaiian
Status: offline
Joe,
I have not heard from Chris about price yet, but I will get you answer tomorrow. Also I did get an update from Chris regarding the Main Rudder Control Servo Arm. He recommends the SWB 4.5" straight arm, which should work fine with the fiber glass control arms that is included in the kit.
