RE: Extreme Flight 110" 100cc Yak 54 Build!
Tower Hobbies
Logged in as Guest
Users viewing this topic: kochj
  Printable Version
Composite-ARF Extra 260 2.6m - RTF
Seller:  96918
Details:   $4,300.00   |  11/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight 110" 100cc Yak 54 Build!
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/22/2007 1:44:05 PM
Flyin Hawaiian
Status: offline
Joe, yes I routed the lines out the side to make sure I cleared the pipes.
Okay guys. I know some of you wanted to see some comparison pics with the QQ Yak. I also thre in little brother, the 88" EF Yak 54. So I got off work early, and it was so nice outside. So I shoveled some snow out of the way , and took some pics.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Rennie "Fly Low & Slow & In Control!"
Team Extreme of extremeflightrc.com / B & E Graphix
(in reply to Josey Wales)
       Post #: 126
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/22/2007 1:46:20 PM
Flyin Hawaiian
Status: offline
Here are some pics of the 110" assembled for the first time! (the word is BIG!)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Flyin Hawaiian)
       Post #: 127
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/22/2007 2:06:37 PM
Flyin Hawaiian
Status: offline
Okay, moving along.........
I finished up the cowl baffle and cowl mounting. The Baffle plate is a little thin for my liking. (Sorry Chris). Like the 88" Yak I reinforced the baffle with some fiberglass cloth and thinned epoxy. on my 88" Yak the plastic baffle started cracking because of the air pushing on it.
First I determined which louvers I wanted to cut-out. Then I cut a piece of FG cloth and made sure that I covered the cut-out area. Masked off and shot some 3M spray adhesive, and tacked down the cloth. Then with some 15 min epoxy, thinned a little with some rubbing alcohol, and lightly brushed it on. I would of used light-weight FG cloth, but I used what I had on hand. After the whole mess cured, I cut out the intake holes, cut-sanded-epoxied the baffle plate in the cowl. I finished off the baffle with a little black model paint. once the Baffle was set, I cut holes in the cowl for fuel dot, vent line, and access needle adjustments. I am not running a choke servo or linkage. I just have a hole on the bottom of the cowl so that I can just 'finger' the choke.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 128
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/22/2007 2:23:36 PM
Josey Wales
Status: offline
Good idea on the baffle--I will be doing that as well. Nice pics also..looks like when all 3 are lined up the gear location is about the same for all three--good for me since I gotta fit it in a 6 1/2' pickup bed!
Joe
       Post #: 129
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/22/2007 2:26:15 PM
wifpwcf
Status: offline
1 word NICE !!!!!!!!!!!!!!!!!!!!!!!!!!!
TEAM AUSTARS,TEAM TO MUCH FUN CLUB
TEAM BIG COURAGE DIAMONDS
       Post #: 130
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/22/2007 4:31:43 PM
xtraflyr
Status: offline
Very SCHWEET Rennie!! Ill tell you what.. I like it naked without graphics. My 88 is the same way except for 2 TBM graphics. THink Im gonna keep it that way.. Funny how the 88" looks bigger then the QQ 102" Lets us know how they compare.
Cya,
Frank
ps.Dont joke around about shoveling snow Rennie!! HAHAHA!!!
www.njjf.org
www.njjf.freeforums.org
(in reply to wifpwcf)
       Post #: 131
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/23/2007 2:39:10 AM
patternflyer1
Status: offline
What's snow??
Team Airtronics
(in reply to xtraflyr)
       Post #: 132
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/23/2007 5:03:34 AM
Flyin Hawaiian
Status: offline
quote:
ORIGINAL: patternflyer1
What's snow??
Exactly!
Merry Christmas!
(in reply to patternflyer1)
       Post #: 133
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/23/2007 6:21:02 AM
JoeAirPort
Status: offline
Snow is what I take off and land in with these bad boys.
Not recommended for girly men.
Click for fullsize
Joe AP
       Post #: 134
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/23/2007 6:48:32 AM
patternflyer1
Status: offline
Merry Chrismas to you also my brother.. Great plane you have.. I'm gonna start saving my duckets for one..
Still trying to finish my first gasser at the moment though.. You gasser guys are all genious's in my book..
Electric pattern planes are so much easier.. lol..
Happy holidays.. Looking forward to the video..
Chris
Team Airtronics
       Post #: 135
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/23/2007 6:49:44 AM
patternflyer1
Status: offline
quote:
ORIGINAL: JoeAirPort
Now that just looks wrong.. Really wrong!!
Team Airtronics
(in reply to JoeAirPort)
       Post #: 136
RE: Extreme Flight 110" 100cc Yak 54 Build! - 12/27/2007 4:50:44 AM
Flyin Hawaiian
Status: offline
Hey all,
Glad to see the thread has been active while I have been taking care of family Xmas stuff.
I did have time to get everything ready for CG check and engine testing, but I had a couple of set-backs.
- upon final CG check, I was way nose heavy I have to mount rx batteries at the back end of the canopy area, behind the rudder servos. Because the battery leads are only so long, and I did not want to cut and splice the batt leads, so I had to redo the radio gear lay-out and shift everything back as well. Also I have a alternate ignition battery mount area behind the wingtube just in case I have to move the ignition battery there.
- Chris Hinson sent me a 5" straight SWB rudder servo arm, and the geometry for pull-pull constrols were not correct. The rudder servo arm needed to match the rudder control horns measured at 4-3/8" w/ offset, like the 4" SWB off-set servo arm. So I modified the 4" arm I had and made carbon fiber arm extensions. Worked like a champ, and now I get nice cable tension through-out the whole rudder deflection in both directions.
- One of the used Hitec HS5955TG elevator servos must have a bad circuit board, cause it would not hold programming from the Hitec Servo Programmer, so I went ahead and replaced both elevator servos just to be safe.
Everything is ready for engine test and final check. Maiden willb ethis Friday. Will have pics and video!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
