RE: Extreme Flight 110    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Rcexl Opto Gas Engine Kill Switch ***FREE SHIPPING***
Seller:  swgiantscalemodels
Details:   $13.29   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight 110
Page: <<   < prev  64 65 66 67 68 69 [70] 71 72 73   next >   >>
Login
RE: Extreme Flight 110 - 9/1/2010 11:25 PM
mm
Score: 100
Last Login: 1/8/2013
Status: offline
gboulton,
you said :'Took a pretty fair amount of up elevator', do you know why ? i have the same problem on my 88 EF yak and this week-end, i will search why.
Stephane
Hide Signatures
(in reply to xtraflyr)
       Post #: 1726
RE: Extreme Flight 110 - 9/5/2010 10:41 PM
mm
Score: 100
Status: offline
no ideas for that problem ?
thanks
Stephane
Hide Signatures
(in reply to mm)
       Post #: 1727
RE: Extreme Flight 110 - 9/6/2010 2:42 AM
diamondave
Score: 107
Last Login: 7/4/2012
Status: offline
incidence or cg would be my guess
Hide Signatures
(in reply to mm)
       Post #: 1728
RE: Extreme Flight 110 - 9/6/2010 10:05 PM
mm
Score: 100
Status: offline
well, i haven't seen that problem last week-end, not the time...i'm wondering if it is possible to be other things ???
Stéphane
Hide Signatures
(in reply to diamondave)
       Post #: 1729
RE: Extreme Flight 110 - 9/6/2010 11:13 PM
diamondave
Score: 107
Status: offline
your linkages are still the way they are supposed to be? no servo strip or anything?
Hide Signatures
(in reply to mm)
       Post #: 1730
RE: Extreme Flight 110 - 9/7/2010 11:55 PM
mm
Score: 100
Status: offline
yes, no problems here diamond. I have read on rcu most of pilots has this problem, i 'm wondering why...
Stephane.
Hide Signatures
       Post #: 1731
RE: Extreme Flight 110 - 9/8/2010 2:27 AM
cjcyclesrc
Score: 100
Last Login: 9/19/2011
Status: offline
Stephane,
What problem are you referring to? My 110" and 88" Yak have a little up trim. I wouldn't call it a problem both of them track very straight.
_____________________________
Charles
Fly Extreme!
Hide Signatures
(in reply to mm)
       Post #: 1732
RE: Extreme Flight 110 - 9/8/2010 7:11 PM
Barry Cazier
Score: 100
Last Login: 10/15/2012
Status: offline
My 110 and 88 both have about 4-5 clicks up trim also. Doesn't seem to effect the way they fly, or if it does I don't know how.
Good flying planes.....regardless.
thanks
Barry
Hide Signatures
(in reply to cjcyclesrc)
       Post #: 1733
RE: Extreme Flight 110 - 9/8/2010 7:23 PM
JWilliams
Score: 100
Last Login: 2/6/2013
Status: offline
quote:
ORIGINAL: Barry Cazier
thanks
Barry
That's the attitude, nothing stopping you.
Jeff Williams
Extreme Flight RC, www.bandegraphix.com, team Airtronics
Hide Signatures
(in reply to Barry Cazier)
       Post #: 1734
RE: Extreme Flight 110 - 9/8/2010 11:24 PM
mm
Score: 100
Status: offline
Charles,
i have to add about 31 clicks of uptrim on elevator (5 mm of throw), so it's a problem...
Stephane
Hide Signatures
(in reply to JWilliams)
       Post #: 1735
RE: Extreme Flight 110 - 9/8/2010 11:39 PM
cjcyclesrc
Score: 100
Status: offline
quote:
ORIGINAL: mm
Charles,
Stephane
Stephanie
What radio are you using? What do you have the trim steps set to?
Do you have a picture of the elevators with the radio powered on? 5mm wouldn't be much more than the thickness of the trailing edge of the elevator.
Charles
Fly Extreme!
Hide Signatures
(in reply to mm)
       Post #: 1736
RE: Extreme Flight 110 - 9/9/2010 12:52 AM
mm
Score: 100
Status: offline
i'm using a T10 CAP, i will post pictures so you will see Charles.
Regards
Stephane
Hide Signatures
       Post #: 1737
RE: Extreme Flight 110 - 1/5/2011 10:40 PM
mikefairbanks
Score: 100
Last Login: 6/23/2011
Status: offline
quote:
ORIGINAL: diamondave
joe when i used locktite on the collars i had an even harder time getting them off, i used blue, removabel my a$$ , ended up dremeling them to cut them off, so now i put a dab of clear silicon over the screw when done, i just tried that fuel tube thing too and i like that, i used to put a dap of silicon on the axle, same principle...
It's been a long time since this was posted, but it's still useful to know that a little bit of heat will break down the blue locktite. It's somewhere between 200 and 220 degrees where it lets go. So for a wheel collar, just put your soldering iron right on the set screw for a few seconds, and it will come right out.
I once got some blue locktite into the barrel of a carburator... couldn't move it for anything! Pulled the carb off the motor and dropped it in a pot of water and brought it just to a boil. Pulled the carb out and it came right apart.
Hide Signatures
       Post #: 1738
RE: Extreme Flight 110 - 1/5/2011 11:14 PM
SteveD-RCU
Score: 101
Last Login: 5/15/2013
Status: offline
Going to put my 110 together soon..DA 100 with MTW pipes.
Steve
Steve Daly
MAAC #14007
Hide Signatures
(in reply to mikefairbanks)
       Post #: 1739
RE: Extreme Flight 110 - 1/5/2011 11:52 PM
mikefairbanks
Score: 100
Status: offline
Just got my 110" 2 days ago, but already have almost everything I need to get it together. Here's my setup.
DLE-111
MTW headers into ES Composite pipes
Li-Ion batts, 2x 5200 on the radio, and 1x 2600 for the ignition
Power into a Smart-Fly PowerExpander Competition 12 Plus
Spektrum AR9000 with 2 satellites
Hitec 7955's all around, with a 5245 on the throttle... throttle servo plugged into receiver for regulated power
Kavan Air tires on PSP machined hubs
Graphics by Bad Brad Graphics
5" Mezjlik CF spinner
Custom CF baffles
Here's a pic of my 88"... the 110" will look the same.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to SteveD-RCU)
       Post #: 1740
RE: Extreme Flight 110 - 1/6/2011 12:56 AM
diamondave
Score: 107
Status: offline
nice scenery ......i too have a dle111 in mine, had a zdz100 for the 1st year and half, saw some dles at the field, bought a 55 for myself, liked it so much i pulled the zdz and put the 111 in it, definetly had more power, im diging this set up now, switched to a biela 28-10 and id say its darn near perfect for me, i have a vid on youtube i just made with that set up i can post a link if you want, my older vids shows the zdz, had a vess 27a mostly on that, much better now for sure
Hide Signatures
       Post #: 1741
RE: Extreme Flight 110 - 1/6/2011 6:26 PM
Barry Cazier
Score: 100
Status: offline
Very nice picture.
My 110 has a DA100 on pipes. It's a great combo. I really like the plane.
You'll love yours I'm sure. And you setup sounds nice. It'll work great.
My advice.....double collars on the axles. Or better yet change them for the RPS (?) kind with the locking ring and then put a wheel collar.
My wheels fell off on the first 3 landings. Not pretty. But the damage was moderate each time. But my plane has been repaired 3 times and I only have about 25 flights on it. Something about the harmonics on my particular set up I think as others haven't had the problem. But I wouldn't take the chance.
Have a great time with this.
Barry
PS: Mines red.
Hide Signatures
       Post #: 1742
RE: Extreme Flight 110 - 1/6/2011 11:38 PM
mikefairbanks
Score: 100
Status: offline
DiamondDave, I'd love to see some video with the DLE-111. I ran the DLE-55 in my 88" and really liked it. I was planning to use a Vess 28 A or B on the 111.
Barry, I've got the PSP axles that use the C clips... I really like using the clips on my big airplanes. That and a little bit of silicon tubing pushed on the end of the axle as a last ditch to keep the wheel on. I've had to make 2 or 3 landings of smaller aircraft missing a wheel... it's always exciting! And not in a good way. ;-)
Hide Signatures
       Post #: 1743
RE: Extreme Flight 110 - 1/7/2011 11:47 AM
diamondave
Score: 107
Status: offline
here is me doing some imac stuff with some "fun" stuff at the end, a good hover shows the dle power with the biela prop, i love this set up, f you click on my name you can see my other vids, a dle in my 88edge, and scroll around to see my older vids of my 110 with the zdz in it, i can see/hear a difference in performance too for sure
http://www.youtube.com/watch?v=kjRaoBHgWXQ
Hide Signatures
       Post #: 1744
RE: Extreme Flight 110 - 2/9/2011 10:49 AM
Stormrider5
Score: 100
Last Login: 5/6/2013
Status: offline
Any word when the next batch will be here in the states? I have everything ready and waiting including the new 7x17 legend trailer.
Hide Signatures
       Post #: 1745
RE: Extreme Flight 110 - 2/10/2011 2:02 AM
xtraflyr
Score: 100
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: Stormrider5
Little birdy told me hopefully middle of February. Call or Email EF and they'll tell ya for sure .. I'm also waiting for one,(Russian Thunder). I'm thinking about doing it in the scale Embry Riddle scheme..
Frank
www.njjf.org
www.njjf.freeforums.org
Hide Signatures
(in reply to Stormrider5)
       Post #: 1746
RE: Extreme Flight 110 - 2/10/2011 2:31 PM
exeter_acres
Score: 116
Last Login: 9/24/2012
Status: offline
Container is supposed to be in the States. We are just waiting for the call for delivery.
Best thing is to drop me an email at info@extremeflightrc.com and let me know the airframe and color that you are interested in and I can keep you posted.
Curtis
Extreme Flight RC tech support
IMAC SE Regional Director|IMAC Sequence Committee|IMAC Judging Instructor|Team Futaba
Hide Signatures
       Post #: 1747
RE: Extreme Flight 110 - 2/11/2011 3:49 AM
xtraflyr
Score: 100
Status: offline
quote:
ORIGINAL: exeter_acres
Curtis
www.njjf.org
Hide Signatures
(in reply to exeter_acres)
       Post #: 1748
RE: Extreme Flight 110 - 2/16/2011 4:59 PM
Barry Cazier
Score: 100
Status: offline
According to the website, Extreme Flight has this and most of the other planes in stock now.
The container must have arrived!
Barry
Hide Signatures
       Post #: 1749
RE: Extreme Flight 110 - 2/16/2011 5:03 PM
Barry Cazier
Score: 100
Status: offline
I'm getting anxious to fly. Weather is getting better. Maybe 3-4 weeks we'll be able to get to the flying field.
I'm gonna start finishing my Edge this week. Also, gonna polish the dust off the 110 and 88 and get them ready.
Gonna be a fun year.....well maybe.
thanks
Barry
Hide Signatures
       Post #: 1750
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.846RCU1
