spektrum will not arm esc
Tower Hobbies
Logged in as Guest
  Printable Version
Composite-ARF Extra 260 2.6m - RTF
Seller:  96918
Details:   $4,300.00   |  11/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Glow to Electric Conversions >> spektrum will not arm esc
Page: [1]
Login
spektrum will not arm esc - 12/1/2007 8:49:42 PM
timothy thompson
Status: offline
hi im running a dx7 in my b-25 all controils work fine but the esc"s will not arm. throttle throw set at 100% i get no beeps. jeti 77 esc axi 4130-16 im sure its a programming deal with the radio. any help appreciated
       Post #: 1
RE: spektrum will not arm esc - 12/1/2007 9:56:19 PM
Greg Covey
Status: offline
Not enough information here to properly troubleshoot so I'll make a few suggestions.
1) Be certain the props are off the motors for testing.
2) The Jeti-77 is an Opto ESC so it needs both power to the ESC from the receiver, battery pack, or UBEC. It also needs the main flight pack connected.
3) Try reversing the channel direction on the Spectrum radio.
4) If it is an Advanced PLUS ESC, plug an Rx. battery into the programming card after first connecting the flight pack.
Good luck!
_____________________________
Visit my Web Hangar at www.gregcovey.com/rc.htm
(in reply to timothy thompson)
       Post #: 2
RE: spektrum will not arm esc - 12/2/2007 2:25:12 AM
timothy thompson
Status: offline
it works! you dont cut the red wire and it works. i am amazed that the esc can handle that current. i have 6v for rx and 8s for the motors. I replaced the cut y and the motors spooled right up! nothing got warm at all found a site explaining opto escs and they need rx power. im planning on going 7s each motor 14s total on the plane
< Message edited by timothy thompson -- 12/2/2007 3:53:38 AM >
(in reply to Greg Covey)
       Post #: 3
RE: spektrum will not arm esc - 12/2/2007 9:41:51 PM
Greg Covey
Status: offline
Tim,
Yes, the Jeti-77 is an Opto ESC so there is no BEC to disable. In fact, it needs to be powered from the receiver battery.
Good luck!
       Post #: 4
RE: spektrum will not arm esc - 12/3/2007 6:26:52 AM
timothy thompson
Status: offline
greg electicalc says if i run 45 5000mah each side i will get a 3 min flight. if i go up to 6s i get 8 min and up to 8s each side i would get 14 min. i have a limited size area for the lipos in the b-25 and made a hatch. I can comfortably get both 4s batts in and know i could get 2 additional 2s 5000ma in as they only are 1/2 in thick. the 3s are .8 inch. if you have electricalc or motocals could you run these numbers. packs are 4s 5000mah prodigy packs i each side axi 4140-16 jeti opto 77 esc. wt around 18-19lbs fully loaded. span 88,5 area 1036 loading 38-42
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU4
